    Default Question on foam insulation in a kneewall attic
    I inspected a very upscale home for a relo company a couple of days ago. I'd like feedback on the presence of foam insulation in a crawlspace attic. Both extruded polystyrene and a polyisocyanurate insulation boards were present.
    I know these can't be exposed in a basement or living space, but what about a kneewall attic adjacent to living space. The doors to the space were not all fire rated.
    Looking for answers before I do this report so this doesn't come back to bite me.
    Default Re: Question on foam insulation in a kneewall attic
    Quote Originally Posted by Ernie Simpson View Post
    Ernie,
    I can't imagine it to be a problem. Obviously, if this is installed between studs, there will be gaps where the panel is cut and stuffed into the stud bay, but that should not be a huge deal. If you have specific concerns regarding the method of installation, checking the manufacturer's website would be your best bet.
    Herb Scott's Avatar
    Herb Scott Guest
    Good Question. I've seen it at a number of locations, with the label stating that it must be covered with approved material / 1/2 inch drywall. If I can see any foam insulation, either sprayed or board form, I call it and make my client aware of the potential concerns. Weather or not it needs to be covered in a knee-wall , crawlspace or an attic likely depends on the manufacture,s requirements and / or the municipality's requirements.
