Results 1 to 23 of 23
Thread: Framing... is this ok???
10-12-2008, 06:41 PM #1
The builder began framing on our house last thursday. My husband an i went to to see it on friday, and what we saw.... seemed really shady. There where premade wall panels *(which we knew was common) but lets say it take 15 2x4's to make that panel..... 12 of those 15 boards were made to look like 8 foot 2x4's by being dove tailed pieces fit together.... thats crazy right???? is this normal.... what is the structural integrity of a house when 85% of it is made with scraps piece together???
10-12-2008, 06:54 PM #2
Re: Framing... is this ok???
Your probably seeing finger jointed 2x4's in a vertical position which is normal too see. Not a structural problem whosoever. These types of 2x4's cannot be used in a horizontal position though.
10-12-2008, 06:57 PM #3
Did they look like this?
10-12-2008, 07:30 PM #4
yes... just like that... but not all sections were equal size.... should we back out of buying this house due to that.... or is it common place.
10-12-2008, 07:48 PM #5
Jenni, you should hire an inspector to look at the house and go from there.
10-12-2008, 07:59 PM #6
we have. He's going to go out there when the framing and wiring are complete.... but since the builder we around us and poured our slab with out telling us when they were going to do that (we didn't get a chance to have him inspect the forms). i just wanted to get an idea of if this fram work was ok
10-12-2008, 09:35 PM #7
The boards are not going to be of all equals sizes in between the finger-jointed sections due cutting of the boards.
Let your inspector check it out before jumping to conclusions.
Who's your builder? Send me a private email if you'd like.
10-13-2008, 01:12 AM #8
The lengths are staggered or random much like brickwork which is staggered to create a bond. You don't want all the joints at the same height or level so that the assembly won't tend to crack at the joints. The finger joints are perfectly ok!
Mike
10-13-2008, 05:42 AM #9
In all likelyhood the finger joining would have been done at the mill when the wood was made. The process is becoming more widely used as we become more " green ", as you waste less wood. From all reports I have seen, the joint is at least if not more strong as the uncut portion of wood. However, this strength would be in a compressive state only, not under latteral load, as was previously mentioned.
10-13-2008, 07:17 AM #10
The finger jointed wood studs will not twist, crack, split or cup like the sawn lumber will. It can be an upgrade to get these studs on walls that will have cabinets, they will be straighter and more plumb than regular framed walls. makes it much easier to hang cabinets on.
The only problem I have with finger jointed wood is in window sills and brick molding that does not get regular exterior maintenance. Then you have all kinds of problems.
Ed
10-13-2008, 08:03 AM #11
Acceptable yes maybe, but surely not the best construction practice. If they went for the best price when purching they have to take the questionable construction that goes with it.
10-13-2008, 08:14 AM #12
Why is that Bill? Are you saying that if someone buys an affordable home there is not going to be some "finger jointed" wood?
Why is that even considered questionable. FJ lumber is just a strong if not stronger against breakage than a regular cut 2x4.
I would say 99% of the homes built here have such lumber. It is not used just in affordable homes.
10-13-2008, 08:49 AM #13
I've never seen it here, that doesn't mean it's not permitted. My reply is the result of a personal preference. Even the lower priced homes bacjk here are not using finger jointed framing material. I'm sure it must be ok in your area if they are using them.
The only finger jointed material i have seen is trim. My reply is strictly a personal perference.
10-13-2008, 09:24 AM #14
Bill,
I will agree with you about the finger jointed trim such as crown moldings and base. Its junk.
10-13-2008, 09:38 AM #15
As posted above I have never seen a piece of finger jointed exterior trim that I liked. That brings me to believe that the higher the moisture level is between the walls the quicker the break down of the glue joint (possibly)
Anyways, I like but also dislike fingure jointed lumber for framing. Straighter yes. Stronger, not sure, winds blowing against a wall, I think weaker. Used as king studs for doors and such, don't think it is a good idea.
JMHO
10-13-2008, 09:47 AM #16
Michael,
There is no control or relationship to having or not having the joints align on the construction site.
As you said, yes, the piece of wood are random lengths, and, as Jim said, that was done in the mill. The studs 'may' (although it would be unlikely) all have the joints at the same height in the wall, except that, being random lengths used, that would be highly unlikely.
Yes, finger jointed studs meet the structural requirements for the compressive loads on the studs, however, that does not mean they area stronger than non-finger jointed wood studs - it only means they are 'strong enough'.
10-13-2008, 04:30 PM #17
10-13-2008, 04:30 PM #18
Thanks Gentlemen,
from what I gather, you all are saying that the finger joint framing is acceptable for the interior walls/frame. But that it should not be used for exterior. And when used, it should only be in the vertical position. is that correct? I have to tell you this has made me feel better about the house.... we were one step away from pulling out of this and going elsewhere
10-13-2008, 04:32 PM #19
10-13-2008, 04:58 PM #20
No, that is not what we are saying. There are many areas of the country which have less susceptibility to high wind loading (or high snow loading), and, in other areas, the engineer of record could specify their acceptability, if the engineer determines they are acceptable in exterior walls.
No, his name will be on the plans as the designer of record, could be an architect, could be a structural engineer.
In some areas, no engineer is needed if the house is 'built using the code as the design model', i.e., the code says you can do this, and the contractor does that. However, in many areas of the country, that is not acceptable, the AHJ (Authority Having Jurisdiction) wants an engineer to be responsible.
Last edited by Jerry Peck; 10-13-2008 at 08:21 PM. Reason: fixed a [/quote] which was missing the '/'
10-13-2008, 06:55 PM #21
Jenni,
Just like JP said, if engineered, the approved set of plans will have the engineer's stamp. In my area, pretty much everything has an engineer's stamp. I forget that not all of the U.S. does this, but our ground tends to shake occasionally. I would have assumed that since TX is in the path of the occasional hurricane, engineering would also be required. If there is no structural engineer's stamp on the plans or specifications (usually the term is "professional engineer" or P.E.), then the architect would be the one to question. If no architect, then you are stuck with the builder.
Remember to check the approved plans. The builder will probably have these. The approved set will probably have a city or county stamp on each page. At least, that is what is done around here.
10-13-2008, 08:15 PM #22
I see Stafford is near the coast.
The counties along the coast have a special restriction requiring an engineer to certify the construction since it is in a high wind area.
Since I am far from the coast, I know very little about the process, but I did sit through a continuing education class that taught a little on the subject.
I would bet there is an engineer involved since you can't get insurance without the certificate if the house is located in a high wind area. Get in touch and ask him about the requirements.
10-19-2008, 12:47 PM #23
Finger joint is common around here. Here's everything you need to know about the lumber. http://www.cwc.ca/NR/rdonlyres/676CF...ntedlumber.pdf
