Results 1 to 21 of 21
Thread: Wow...Check this out.
12-07-2008, 11:39 PM #1
I saw this today. It was in the center of the beam which spanned 15ish feet and supported the second floor. Crazy...
Similar Threads:Last edited by Marc M; 01-18-2010 at 09:04 PM.
12-08-2008, 05:08 AM #2
Re: Wow...Check this out.
Marc:
Likely the previous location of a door opener installed by a genius.
Aaron
12-08-2008, 07:40 AM #3
And another genius to remove the offending opener track and LEAVE the notched beam.
'My home inspector said that the garage door opener track should not go through the beam like that, to monitor it, so I removed the garage door opener like my home inspector said to. I do look at that several times a week like my home inspector wanted me to do.'
12-08-2008, 08:14 AM #4
I wish id taken a picture of the "sag" in the member, but there was so much junk in that garage I couldnt get back far enough.
12-08-2008, 12:29 PM #5
That big post in the middle of the garage is gonna be a bummer.
12-08-2008, 01:05 PM #6
That beam is nothing I tell you, NOTHING!
I have an 8" x 8" x 20' beam on the 2nd floor of my house where they had notched a 30" section to a thickness of 2" to provide headroom in the hallway (part of a 12' span).
Or the 6" x 6" x 20' beam on the 1st floor where they had a single column to cut the main span to a mere 14' and the beam is notched 3" at the top to receive the floor joists. (Is there a name for this construction technique - other than "improper"?)
Or how about the 8" x 8" x 20' beam in my basement where they had removed all of the inconvenient posts to accommodate a water heater. Plus, the previous owner couldn't stomach the idea of killing her poor little powder post beetle friends... talk about beam deflection.
Or how about the... okay, I'll stop now. We've all seen it before.
12-08-2008, 01:35 PM #7
This was just singed off by the city Build inspector. the dude never check the attic framing just the sheathing from the street. areas of the sheathing was off the original rafters more then 2"INCH.
But if the city guy says its ok its must be ok...
One way to take out the uneven areas of the roof
Best
Ron
12-08-2008, 01:46 PM #8
12-08-2008, 04:46 PM #9
Shoot. That beam is probably just holding up a king size water bed on the second floor. No problemo.
12-08-2008, 07:19 PM #10
12-09-2008, 08:33 AM #11
Ron, what you took pictures of is typical framing for that era of houses.....50's---60's.
If anything they made the rafters stronger by doubling up the 2X4 rafters with the scab-on.
12-09-2008, 09:02 AM #12
The only thing that is holding up the sheathing is the nails of the 2x4. there is no support for the kickers or the 2x4 just nails. One of the hips has a plywood scab on one side with no support. this framing is a mess. would buy that?
this was all done just this year.
Best
Ron
12-09-2008, 09:02 AM #13
The protection from fire impingment provided by the gypsum was removed when the notch was cut into the beam.
12-09-2008, 09:11 AM #14
So what is the suggestion in the end? Definitely "wrong" or refer to a PE for evaluation?
For all we know, the beam could have been oversized (I know, not likely) and the notch is still within the load tolerances. I've certainly oversized a number of beams and headers in the past, you know, just in case someone down the road wants to put a hot tub on the porch roof.
12-09-2008, 09:40 AM #15
No need to spend the clients money on an engineer, have them get it repaired. No further study or evaluation needed. It is broken, fix it.
If the person doing the repairs needs an engineer to design a fix (not likely) then let them pay for it and include it in the repair estimate.)
12-09-2008, 09:53 AM #16
If it was done this year then a positive NO! The reason I stated what I did because it looks like the framing methods were from the 50' - 60's.
Maybe an "old" carpenter did it!
Sure don't build em like they used too!!! I always say...Thank GOD!
The wood sure looks like it has been there a long time...with the sap and discolorization to it though!
12-09-2008, 10:31 AM #17
The original was from the 50/60. but then the were trying to fix the uneven drop in the rafters. and added the 2x4s and the new roof sheathing. the city inspector did not check the framing of the attic he just look at the sheathing from on top.
Best
Ron
12-09-2008, 11:33 AM #18
This is one of those things that you guys (HI's) have the upper hand on.
You can report that the framing does not comform to current standards where the AHJ cannot require the contractor to bring things up to current codes. Unless work is being performed on that portion of the structure.
That may be why the BI passed it. Not trying to defend him but there is a lot of difference between a HI and a BI on what the laws allow.
12-09-2008, 02:29 PM #19
12-09-2008, 03:08 PM #20
Im with you. My company represents the agent / bank for the repairs so there isnt a buyer for this particular house, yet. But it is scheduled to be repaired. And yes, we're going to have an engineer figure out a repair or R&R the beam. BTY, its not a typical beam, it looks like 3 pcs of 2" plywood glued together. But according to IRC R502.8 & 502.8.8., specifically the latter of the two; suggests that this may be engineered and therefore un-notchable? As if...
12-09-2008, 06:58 PM #21
Might they be 1-3/4" in which case it may be three plies of LVL. See http://www.ilevel.com/literature/TJ-9000.pdf pg 38 assembly B for an example.
If joined properly three plies of LVL can be quite strong. Without suggesting that you practice engineering without a license, you can perform some quick back of the envelope calculations to determine what size beam should be there. Figure out the total square footage supported by the beam and multiply that by the LL + DL (let's assume 40LL + 20DL). Divide this by the beam span to get our lbs per lineal foot (plf). We'll then look in the appropriate table to determine the minimum beam size appropriate for the total load and live load.
