Results 1 to 11 of 11
Thread: 1970 Home odd wall system
02-22-2009, 11:57 AM #1
Look at the photos of these exterior walls. 2x6 T&G on the inside Over plywood over a foam with an exterior plywood siding. This is the way all the walls were constructed. Ever see this before? No visible paper.
They cut open a section of the wall to install a door and use the cut out for the door.
Any ideas. Thanks...
Best
Ron
02-22-2009, 12:11 PM #2
Re: 1970 Home odd wall system
Post and beam tyope home with the partial logs secured to the posts and then the rest of the system. Gives it that log cabin effect. actuall, all the would and the foam in the middle was fairly efficient. Those home make a nice camp fire once the get ripping on fire. I acually like them.
02-22-2009, 06:08 PM #3
Very common for post and beam cabins. Nice to see a cut away view once in awhile.
02-22-2009, 06:48 PM #4
Pre fab, faux post and beam.
02-22-2009, 07:30 PM #5
Do you think they have damage the wall system by cutting the wall like this?
Best
Ron
02-22-2009, 07:41 PM #6
02-22-2009, 07:54 PM #7
03-03-2009, 09:49 AM #8
I LOVE SOLID CONSTRUCTION. IT GIVES A NICE RUSTIC FEEL TO THE HOME.
03-03-2009, 11:11 PM #9
I saw quite a few of these "Lindal Cedar Homes" up here in the 70's.
lindal.com/homes/
They could be bought as a kit, sadly lacking in insulation for the most part. Like a 4" thick panabode wall. Cedar was cheap and plentiful and so was firewood.
John Kogel
Home Inspection in Victoria BC, Sidney, Sooke, Saanich, Duncan, Cobble Hill, Mill Bay, Chemainus, Crofton, home inspector
03-04-2009, 04:44 AM #10
03-04-2009, 09:44 PM #11
I learned something at a code seminar the other day of which your photo reminded me. Timber frame type construction requires no enclosed air spaces in the framing. That's why all the rafters and beams in the partitions are visible throughout. I wonder if this is related to the foam filling the space?
As someone related above, wood makes good fuel. They almost never cover walls with drywall in a timber frame home. Also the minimum sizes of the beams are specified in the code. In lieu of the 1 hour fire rated materials liek drywall they figure that burning through them would take an hour. Unlike metal, wood actually gets stronger before it eventually turns into charcoal.
In this case it would be the fumes of melting plastic foam that would get you.
