Results 1 to 13 of 13
    Default crack of the month
    Older structural brick - not veneer. Can't really see the lateral displacement and bulging so well in the photos. This is the worst I've seen in quite a while. Not sure how to fix, but then that's not my job.
    Colorado Springs, CO
    Default Re: crack of the month
    It's already been repaired. See the earthquake rod? That will hold the brick in place (i.e., keep the brick from moving out on this and the opposite face). Earthquake rods installed perpendicular to this one will help keep this crack from widening.
    Actually, while earthquake rods are a big improvement they are not the final solution. I remember seeing earthquake rods on many old brick buildings in Charleston. Not sure how effective they are in a large earthquake but they were probably cutting-edge techology in earthquake-proofing buildings circa 1890.
    Bruce Breedlove
    www.avaloninspection.com
    David Banks's Avatar
    David Banks Guest
    Scroll down to Bulging of walls.
    Above-ground masonry walls - Oldhouseweb.com
    I think the cause of that crack is quite apparent.........that pen is forcing the wall apart. If you remove the pen, everything should go back to normal .
    Nick - You know what they say: the pen is mightier than the ... star anchor?
    We never called them "earthquake rods", but installed them to help retain the outer wythe of brick walls on a few older homes. We simply called them tie backs and stars anchors.
    I like the explanation given in the link David provided, but settlement can also cause variations of that bulging.
    My response was about 90% tongue-in-cheek.
    Bruce Breedlove
    Quote Originally Posted by Bruce Breedlove View Post
    In Gainesville, Florida, we had some old brick structures, many had those tie backs and stars installed to retain the brick walls from movement/bulging/etc.
    Thus I did not make the 90% connection.
    Sometimes the anchors work and sometimes they don't.
    Yep. I've seen that too.
    Corpus Christi, TX
    The engineer agreed this crack did not need repairs.
    - Paul Fix
    James Duffin's Avatar
    James Duffin Guest
    Yep....don't need repair but sure needs me!
    Jon Randolph's Avatar
    Jon Randolph Guest
    Correct me if I am wrong, but with that wall type, shouldn't there be cross ties every 6 rows?
    By the way, Thom, would advise to cover and hide that crack. Major safety concern.
    "In the news today, an amish waoman and her 6 childred died when the husband (father) veered his carriage into traffic while looking at a road side sign. Man survived, but is said to be going blind."
