Results 1 to 11 of 11
Thread: Stair stringer
06-22-2009, 04:49 PM #1
Stair stringer
Can I cut into one of the stringers that support the stairs to my second floor in order to relocate a door? If the answer is yes, then how do I reinforce the weakened stringer? I realize this is not ideal, but the relocated door is, so any help/ideas would be appreciated. Sorry no pics.
06-22-2009, 05:58 PM #2
Re: Stair stringer
I am having a difficult time visualizing cutting into a stringer and not having a door open to the stairway - which would be major no-no.
Pleases explain or describe in greater detail.
06-22-2009, 10:01 PM #3
Re: Stair stringer
06-22-2009, 10:06 PM #4
Re: Stair stringer
06-23-2009, 05:22 AM #5
Re: Stair stringer
06-23-2009, 07:24 AM #6
Re: Stair stringer
You'd have to take a pic so we could see exactly what you are dealing with. You could cut the stringer, but you'd have to do much more than just cutting the stringer. Cutting all of the stringers and installing a landing may work depending on your application, and could give you more head room.
06-23-2009, 07:29 AM #7
Re: Stair stringer
*IF* the door was framed such that it effectively supported the stringer as a column and beam, and laterally supported the stringer so it could not move laterally, it *could* be done.
Think of it as landing and bearing the stringer on a landing at the top of the stringer and then at the bottom of the stringer.
It *could* be done, with emphasis on *could*, but it would need to be done correctly.
06-23-2009, 07:41 AM #8
Re: Stair stringer
I think from now on, we all need to request pictures before answering some of these questions.....
06-23-2009, 08:39 AM #9
Re: Stair stringer
06-23-2009, 09:05 AM #10
Re: Stair stringer
Except that not everyone always has photos, especially of things they are proposing to do.
Drawings and sketches would help, but not everyone can do that.
06-23-2009, 10:04 AM #11
Re: Stair stringer
