Results 1 to 9 of 9
    Mar 2008
    Brea, Ca.
    Default Hmmmm... What do you think?!!
    I came across this in a crawlspace today....I have my own opinion but just wanted to hear others
    Default Re: Hmmmm... What do you think?!!
    Balancing act trying out for the circus?
    It doesn't appear that the beam is pocketed into the wall. Needless to say a 1x3 doesn't cut it for appropriate support.
    Connecticut
    Oh! and after you finish fixing that fascia can you can resupport the main beam in the crawlspace. And if your thirsty you can drink from the hose.
    Your check for 10$ is in the mail
    1.Nice beam but it needs a post of equal thickness.
    2. Recommend a poly vapor barrier on that dirt.
    3. Galvanized plumbing is not popular with insurance companies because it rusts and leaks. Potential deal-killer.
    Apr 2007
    gainesville fl
    nothing like a good laugh while crawling around.
    Mar 2008
    Brea, Ca.
    Hey Bruce,
    I had to refrain from belly laughing while the client was standing above!!!
    Mike
    Have you guys ever considered the possibility that the 1X3 is holding the concrete block DOWN? You're so quick to jump to conclusions!
    James Vincent's Avatar
    James Vincent Guest
    As Henry Gibson once said- Veeeeery Interesting!
