Results 1 to 3 of 3
    Alfredo R. Trevino's Avatar
    Alfredo R. Trevino Guest
    Default When are portal shear walls needed?
    I am designing a free standing two car garage the size is 24 feet wide by 24 feet deep. Do I need to provide a shear wall on each side of the garge openings if the side walls are less than 4 feet wide? Please help me understand when the shear walls are required.
    Thanks,
    Alfred
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: When are portal shear walls needed?
    Quote Originally Posted by Alfredo R. Trevino View Post
    Thanks,
    Alfred
    AT: Wood Strong-Wall®: Garage Portal Systems on Concrete Foundations
    Valerie Gillespie's Avatar
    Valerie Gillespie Guest
    Hey Alfredo, how's it going? Yes you need portals/shear walls. The IRC doesn't make it easy to figure out what is required but based on your description, NJ wind loads, and my experience, you have to do it. Use Simpson Strong Wall or Portal system depending on calculated wind load. Also, the Simpson Strong Wall anchoring assumes a concrete foundation wall (CMU would be less capacity) for anchor uplift, so unless they've come out with a new catalog, the foundation wall for the front of the garage should be concrete not block. Good Luck.
