Thread: Missing tie betweem timber beams
11-18-2009, 08:05 AM #1
Is a strap, plate, or tie required at the end bearing and joint between the two beams? The place was built in 2008 and this is under a canopy entry. The column is anchored into a concrete footing. But as you can see they simply toe nailed the two together.
11-18-2009, 11:13 AM #2
Re: Missing tie betweem timber beams
11-18-2009, 11:32 AM #3
11-18-2009, 05:56 PM #4
A.D,
Thanks that is a nice link.
