Thread: Cut out
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Cut out
    Any thoughts on the way this area has been cut out?
    Thanks,
    Ryan
    Inspection Referral SOC
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Cut out
    RS: Typical HVAC crew hack job. I would report the field alteration of the top plate as atypical and almost certainly not according to the original building plans, and require further investigation by a structural engineer.
    Default Re: Cut out
    Ryan, I need more information on what I'm looking at before I follow A.D.'s lead and condemn it. I think I see the top of a basement wall with a air vent passing into a chase which may turn vertical. The chase needs to be fire-stopped at a minimum and I would need a longer establishing shot to observe the load paths before commenting on the carpentry.
    Ryan Stouffer Guest
    Default Re: Cut out
    Any more thoughts on this cut out. Does anyone recommend reporting on it or just letting it go?
    Thanks,
    Ryan
    Jun 2008
    Stacy, MN
    Default Re: Cut out
    The TJI perpendicular to the wall needs a joist hanger.
    Sep 2007
    Morris, Illinois
    Default Re: Cut out
    Definately report it. There are many ways to correct this defect. Let the client decide what to do next. Your observation, guidance on what to do is what the clients pay for . . .
    "Cut / damaged floor/ceiling support structure present. Further evaluation and correction by a qualified contractor advised. (carpenter)
    Just my opinion.
    Aug 2009
    Michigan
    Default Re: Cut out
    It just needs a joist hanger. There is just one I joist cut and and the two joist on either side have bearing to the foundation wall. No need for an engineer, unless there is something on the other side of the wall we can't see. Gotta love the HVAC guys. They are handy with sawzall...
    Randy Gordon, construction
