Thread: Sill plate
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Sill plate
    This sill plate does not appear to be pressure treated. If a gasket is present does the sill need to be pressure treated. House was built in 1990.
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Sill plate
    MS: If it is less than 8" above grade.
    Thanks AD
    Apr 2007
    state of jefferson
    matthew,
    it could be redwood which is a suitable substitute for pressure treated wood. see 2304.11.2.2 ibc
    Nope, not "redwood" ... must be "heartwood".
    NATURALLY DURABLE WOOD. The heartwood of the following species with the exception that an occasional piece with corner sapwood is permitted if 90 percent or more of the width of each side on which it occurs is heartwood.
    - Decay resistant. Redwood, cedar, black locust and black walnut.
    - Termite resistant. Redwood and Eastern red cedar.
    Last edited by Jerry Peck; 02-17-2010 at 06:44 PM. Reason: trying to fix the stupid formatting
    Apr 2007
    state of jefferson
    jerry,
    thanks for stating the obvious for those with a shoe size IQ .your good for that
