Thread: Covering up framing
02-22-2010, 05:37 AM #1
Covering up framing
During an inspection of a 1920s flipped house, I got into the basement and everything was sealed up with a plastic vapor barrier and was then painted over.
This house was re done from top to bottom but I have never seen anyone install a vapor barrier in the basement so my first reaction is that they are trying to hide something.
The question is, what to say. I don't want to speculate but I can't take the barrier down to look. Although I would be covered legally, I would hate something to be wrong that I can't alert the client about.
Any suggestions? Verbiage, recommendations for the client?
02-22-2010, 07:04 AM #2
Re: Covering up framing
BASEMENT - The basement framing and exterior walls could not be inspected to assess conditions. Walls are covered with a heavy vapor barrier that is also painted over. This is NOT a common or typical procedure. This type of 'covering' installation should be considered suspect. It may be just an inappropriate DIY fix and there may be nothing wrong at all. On the other hand, the covering may be there to hide various problems.
I suggest you consider:
- asking Seller to provide written explanation for the installation
- asking Seller to remove the vapor barrier to allow assessment of wall conditions
- Ask for this prior to closing
If there are problems under the vapor barrier, repair costs could be very high.
This is along the lines of what my report would say. Having done the HI, it would be worded stronger or differently depending. Good luck
02-22-2010, 08:57 AM #3
Basement walls not accessible and were not inspected. Unsure of purpose of plastic wall covering. Recommend consulting the current owner for explanation.
James Bohac
02-22-2010, 01:34 PM #4
They claimed it was a vapor barrier but it didn't make any sense to me.
Not done by a building envelope professional.
02-22-2010, 02:34 PM #5
If they must use a vapor barrier it should be a painted on type... and, really, if they need a vapor barrier that bad they should fix the reason they need one (grading/drainage outside, etc.).
IMO in most cases trying to stop moisture from inside a basement or crawl space is fixing the symptom not the disease.
02-22-2010, 03:09 PM #6
As you know, that painted vapor barrier could very well be hiding something.
I had a similar situation a couple of years ago that led to a complaint. After the buyer (my client) moved in there was a leak through the concrete basement foundation wall. She said I should have notice honeycomb (that was visible on the exterior of the foundation near grade) extended all the way through the foundation wall and provided a pathway for water to enter the basement. After a heavy rain enough water flowed into the basement to wet a good deal of carpet, damage drywall and wet some furnishings.
The buyer was angry that I had not observed the honeycomb on the inside of the foundation wall in the mechanical room. I had reported water on the floor of the mechanical room and stated the source was unknown but could have been caused by workers who serviced the water softener and pressure tank that morning.
When I went back to the house I told her that the foundation wall at the mechanical room was not visible at the time of the inspection because it was hidden behind a framed wall that had been insulated and covered with a vapor barrier. After their basement flooded someone had removed the vapor barrier and insulation and the source of the leak (the honeycomb) was plainly visible. I told the buyer that the honeycomb was hidden at the time of the inspection and I could not be expected to find it. I also told her the sellers possibly hid the leak. (Turns out a plumber that worked on something in the mechanical room told the buyer he had been out before to find a leak in the mechanical room and found none and the water on the floor had come through the honeycomb in the foundation wall.)
Bruce Breedlove
www.avaloninspection.com
02-24-2010, 07:09 AM #7
