Results 1 to 10 of 10
03-23-2010, 01:32 PM #1
Manufactured vs. Modular vs. Site Built
I did an inspection last week of a 1985 house that looks like it is site-built. The appraiser feels that it may be a Manufactured or Modular home.
There are no serial number plates viewable, no tongue/wheels, there is no conspicuous cover-board that would indicate two joined units(the shape/size of the home is a box about 24X50' + a garage with a gable roof), and the floor joists sit on top of the two main 4X8 girders/beams. Wouldn't a manufactured home have 3 or 4 girders/beams too support both halves?
Have I overlooked anything that would point to it not being a site-built house? My pictures of the attic and crawlspace aren't clear enough to show the end walls. Is there anything else I should be looking at?
Is there another class of home that is a hybrid(mid-way between modular and site-built?
Thanks for any helpful comments,
~Don
Similar Threads:Last edited by Don Burbach; 03-24-2010 at 07:45 AM.
03-23-2010, 04:12 PM #2
Re: Manufactured vs. Modular vs. Site Built
Look at the trusses. You generally will see fold-able trusses or sectional trusses that join in the center of the home.
03-23-2010, 04:46 PM #3
Higher end modulars can be pretty hard to tell from site built after the fact. I wouldn't worry about it. Put it back onto the appraiser for evidence of why he thinks it is not site built. How old is it? The original owners would certainly know.
It appears that it is obviously not a mobile home, so does it make any difference in your area?
03-23-2010, 04:53 PM #4
There is a big difference between a manufactured home (mobile home) and a modular home. There is little difference between a modular and site built home, I personally feel site built homes are better but that is just my opinion.
Modular homes are put together in sections but not necessarily in halves like a mobile home. There are junction boxes where the wiring for the sections are connected together, but the easiest way is to look up the permit.
03-23-2010, 08:17 PM #5
03-23-2010, 09:17 PM #6
The manufactured homes I've seen sit on a steel frame instead of wood framed floor and rim joists.
03-23-2010, 09:18 PM #7
03-24-2010, 08:05 AM #8
03-24-2010, 08:15 AM #9
Whoops, home was built in 1985. I didn't deal with the appraiser directly. I agree with all that a modular home is close to a site-built, but the buyer(the daughter of the real estate agent) is concerned about resale value.
I just reviewed the 6-7 photos I took in the attic space and there is nothing unusual. One of the photos was of the center end-wall and it didn't have anything to indicate that it was brought to the site in two pieces, nor did pictures of the trusses.
I'm satisfied that it was built on site for now, but will ask that the appraiser call me if he thinks it wasn't.
Thanks all, for your help!
03-24-2010, 08:39 PM #10
I did a modular this winter that was more or less square in layout, with a pyramid-style hip roof and a wing added to one side for a garage.
The only real evidence was in the crawlspace, they used trusses instead of I-beams or joists, and the trusses were doubled up down the centerline. I think there was a set of doubled trusses in the attic as well.
