Results 1 to 2 of 2
Thread: Remodel
07-05-2007, 03:37 PM #1
Remodel
Similar Threads:Last edited by RobertSmith; 12-20-2007 at 03:58 PM.
07-05-2007, 04:12 PM #2
Re: Remodel
I'm sure those good ole boys down there at the Austin Building Dept. checked it all out well during the remodeling process.
Must have had a green tag don't you think?
Seriously hard to tell much from the pictures, but in picture #4 that 2x4 under the window frame is definately prone to some wood decay. Water running in from the outside from the fountain has to be causing some issues I would think.
If the original patio pour was still used for the room enclosure and the above room addition, then I would definately recommend a SE.
Any closer up pics?
