Results 1 to 9 of 9
05-25-2010, 04:01 PM #1
Wow, how would you call this one?
This is a picture of the roof structure which was added on to a attached garage. They appeared to be 2X8 cut down on both ends to about 2 inches. Because of the insulation could not be sure. they were also on 4 foot center. The other pic is what was used to support them where the two structures came together. So how would you call it?
05-25-2010, 05:06 PM #2
Re: Wow, how would you call this one?
Dumb.
05-25-2010, 05:23 PM #3
You got that right! This house was sold once prior to this and this was not called out to new owner. So he says.
05-25-2010, 06:09 PM #4
It appears to be modified pole barn construction.
05-25-2010, 07:15 PM #5
In this area polystyrene board can not be exposed because it burns readily and emits toxic fumes. This may just be a local code but it might be something worth checking into.
05-26-2010, 04:04 PM #6
05-26-2010, 05:16 PM #7
05-26-2010, 06:13 PM #8
05-26-2010, 06:31 PM #9
Back in early 80's I was installing a flat plate collector that was insulated with an inch of double foil faced polyisocyaurate. I do not know the manufacturer.
