    Sep 2009
    McAllen, Texas
    Default Pressure treated for wall studs
    Can a load bearing wall have pressure treated studs or are the only allowed to be used for bottom plates.
    Richard Flores
    Professional Inspector TREC # 8139
    www.premier-rgv.com
    Sep 2008
    Texas
    Default Re: Pressure treated for wall studs
    I don't see any problem with it. PT wood is just regular wood that has been treated.
    That is an interesting question though!
    Sep 2009
    McAllen, Texas
    Thanks for the quick reply. A typical homeowner that claims he was a contractor said that you can't use it. I had never heard of it, so I guess I am going to have to look at my Code book..
    Richard Flores
    www.premier-rgv.com
    Sep 2008
    Texas
    As long as the PT lumber is grade stamped....I don't see a problem.
    From the 2006 IRC
    SECTION R602
    WOOD WALL FRAMING
    R602.1 Identification.
    Load-bearing dimension lumber for
    studs, plates and headers shall be identified by a grade mark of
    a lumber grading or inspection agency that has been approved
    by an accreditation body that complies withDOCPS 20. In lieu
    of a grade mark, a certification of inspection issued by a lumber
    grading or inspection agency meeting the requirements of this
    section shall be accepted.
    R602.1.1 End-jointed lumber.
    Approved end-jointed lumber
    identified by a grade mark conforming to Section
    R602.1 may be used interchangeably with solid-sawn members
    of the same species and grade.
    R602.1.2 Structural glued laminated timbers.
    Glued
    laminated timbers shall be manufactured and identified as
    required in AITC A190.1 and ASTM D 3737.
    R602.2 Grade.
    Studs shall be a minimum No. 3, standard or
    stud grade lumber.
    Exception:
    Bearing studs not supporting floors and
    nonbearing studs may be utility grade lumber, provided the
    studs are spaced in accordance with Table R602.3(5).
    Sep 2009
    McAllen, Texas
    Thanks..That is exactly what I was looking for...
    Richard Flores
    www.premier-rgv.com
    chris mcintyre's Avatar
    chris mcintyre Guest
    It may not be a code issue but IMO it is not a good idea for a couple of reasons.
    1) Treated lumber shrinks as it dries and not at the same rate. You can cut the ends of the decking boards in a straight line and 6 months later they will vary in length a 1/2" or more.
    2) If you use PT studs you would have make sure everyone was using the right fasteners for sheathing, wall ties, siding, drywall, trim, cabinets, etc...
    Elliot Franson's Avatar
    Elliot Franson Guest
    With the known shrinkage and warpage issues in CCA and other pressure-treated dimensional lumber, it would be unwise, in my opinion to use this for wall studs. Just my opinion.
