    Default Minimum throat depth for conventional wood stringers
    Does the IRC specify a minimum throat depth at stringers cut from conventional lumber, or is there another source for such recommendations? (I can find a lot of information on-line for engineered wood products used as stringers, but nothing for conventional sawn lumber...)
    Thanks.
    James Duffin's Avatar
    James Duffin Guest
    Default Re: Minimum throat depth for conventional wood stringers
    I don't see anything in the NC code about stringer size....
    Garland, TX
    might get shot for this but as i recall from wood framing days
    Throat depth:
    3½” for 9½” stringer
    5⅞” for 11⅞” stringer
    8” for 14” stringer
    Lumber should be Min. No. 2 hem-fir, spruce-pine-fir or better grade
    let the bullets fly
    Barry,
    That's what is called for by Boise Cascade for their Versa- Lam stringers. http://www.bc.com/dms/wood/ewp/3_Gui...rstep.ptdddddd
    I've seen both 4 and 5" min. called for with conventional lumber, so I am curious as well.............The American Wood Council calls for a min. 5" throat: http://vil.albion.ny.us/content/Depa...ts/File/51.pdf Fig. 28
