Results 1 to 23 of 23
Thread: Exterior bricks pulling apart
08-09-2010, 06:28 AM #1
In one corner of my brick home, that sits on a slab we notice a year or two ago the bricks where pulling apart. We didn't think to much of it at first and caulked the open areas. Yesterday we noticed that it has gotten worse and you can tell on the opposite side where the bricks are being pushed out. Hence the bricks are pulling away , they appear to lean on the opposite side thus pushing that side out. I will try to post pictures, the 1st time it wouldn't take. The side being pushed out isn't very noticeable and I didn't take pictures of it since it won't show up in a photo. Their is nothing going on inside the the home, opposite of where this is happening outside. The crack/pulling apart is larger at the top and gets narrower toward the bottom. Would checking in the attic help find why this is happening or removing the paneling on the wall inside help. The inside wall in paneling and not plastering and thus removing it wouldn't be a big issue. Would checking these areas be a waste of time. What could be the issue and how would it be fixed?
Okay, having a hard time loading photos, it's jpg.
08-09-2010, 08:09 AM #2
Re: Exterior bricks pulling apart
No, I would not recommend removing anything at this point just to look inside the wall, you will not likely find any cause there.
Pictures would help but it sounds like the foundation might be moving causing the cracks. Looking at the overall structure with a trained eye would tell the tail. At this point I would recommend finding an experienced home inspector to look at it in person.
08-09-2010, 12:05 PM #3
[QUOTE foundation might be moving causing the cracks. .[/QUOTE]
That's what we where thinking. What's the repair $ range for something like that?
08-09-2010, 12:14 PM #4
From zero to tens of thousands of dollars. No way to tell from here. Get a professional evaluation.
You can get a foundation repair company to give you a free estimate but I would not trust them as far as I can throw them. There are some really good guys and some slugs and thus their opinion is worth about what you pay for it in most cases. Follow the money.
08-09-2010, 12:26 PM #5
How would I know a good one from a bad one? I've been searching for whom to call and want to know what the right way to repair it would be.
How do I post photos on here. I go to the link under this box "upload photos" and my pics are jpg. Is their something I don't know?
08-09-2010, 12:27 PM #6
I would suggest getting a structural engineer to write up a repair method and then get estimates from foundation companies. Sometimes it is better to get an unbiased opinion from someone who is not going to do the repair. A SE around here would cost you $300-400.
08-09-2010, 12:49 PM #7
The home was built in the late '80's we purchased it in '02 from the org. owners. They still farm the land around us. A SE, gosh we live in rural AR, don't know if their are people around here with that fancy of a title. Is their a website that would make searching for one easier?
08-09-2010, 12:54 PM #8
Doe syour camera have a VGA mode or an Email mode for photos. I have a feeling your current pics are too large for posting. Take new pics in VGA or Email mode and see if that helps you out with posting pics on here.
08-09-2010, 03:50 PM #9
08-09-2010, 04:33 PM #10
Try this link. It may help you find a SE in your area...
Architects | Landscape, Residential Architects
08-09-2010, 04:38 PM #11
Photos, thanks for the VGA hint
The one photo should show the entire crack, it mets up with the window and then down below.
The 2nd photo you may not be able to tell how the bricks are pushed out a tad. Also the fascia.
08-09-2010, 05:22 PM #12
08-09-2010, 05:36 PM #13
08-09-2010, 05:49 PM #14
Hire an independent foundation / structural engineer to design the repair and then a separate foundation repair company to do the work. This should include testing of both the water and sewer lines for leaks before and after the work. That is a bathroom window in the photo right?
It is pretty obvious from your photos that the foundation has moved. Even the roof line is distorted either from the corner dropping or the middle of the house rising from a water leak or other cause. This is a very typical problem around my part of the world. I'm guessing you are on expansive clay soils also.
08-09-2010, 05:51 PM #15
Ann...
I'll tell you what I tell my buyers and sellers when there is a "questionable" foundation problem and then I'll be quiet!
"Even if a SE cost $300 and finds no repair is needed the problem still exists to the naked eye. The SE will give you a letter stating what he found that can be shared with the next buyer. This may eliminate a potential problem when you sell the house."
08-09-2010, 06:55 PM #16
Would it have helped if that house had gutters and downspouts to carry runoff away from the slab?
I don't know anything about expansive soil, but I imagine the problems occur when dry clay absorbs moisture?
08-10-2010, 06:17 AM #17
From the photos I have seen, both these and those sent to my email address, this is definitely a foundation settlement issue. All of the signs are there: brick veneer separated from the window frame, fascia sloping, brick veneer cracking. It is obvious that an engineer is needed to specify repairs.
08-10-2010, 06:54 PM #18
08-10-2010, 06:56 PM #19
08-10-2010, 06:57 PM #20
08-11-2010, 08:30 AM #21
Now it sounds like there are some elevation issues as well. You said earlier the home was built slab-on-grade, I wonder if the inside floor is the same elevation as outside grade ?
You also mentioned it would be fairly easy to remove inside wall panelling, which may be a good idea to see if there is any moisture wicking through at the slab to wall junction, which may reveal further damage, separate from your initial concern.
08-11-2010, 01:41 PM #22
08-11-2010, 07:39 PM #23
Ann
If the picture is not distorted the crack at the top looks about 1" wide and the roof line appears to slope downward to the left. If my geometry is correct the lower left corner of the house foundation in the picture would have to settle about 5/8" to create a 1" crack in that location. Typically all the engineering investigations I do on situations like yours is usually caused by water ponding near the foundation causing the soil to loose its ability to support the house.
I also noticed no gutters, does water accumulate near this corner of the house?
Randy Mayo, P.E.
RLM & Associates, LLC
