Results 1 to 14 of 14
Thread: Car Repair Pit
01-25-2011, 05:20 PM #1
Car Repair Pit
Does the IRC address anything about a car repair pit? Anything special you can think of that I should mention to the clients. We talked about covering it, and I think they probably will.
Similar Threads:Jim Robinson
01-25-2011, 06:14 PM #2
Re: Car Repair Pit
"The really good ones have steps down at one end".
01-25-2011, 06:14 PM #3
Re: Car Repair Pit
This is from the NC building code...not the NC IRC:
Exception:
Guards are not required for the following locations:
1. On the loading side of loading docks or piers.
2. On the audience side of stages and raised platforms,
including steps leading up to the stage and raised platforms.
3. On raised stage and platform floor areas, such as runways,
ramps and side stages used for entertainment or
presentations.
4. At vertical openings in the performance area of stages
and platforms.
5. At elevated walking surfaces appurtenant to stages
and platforms for access to and utilization of special
lighting or equipment.
6. Along vehicle service pits not accessible to the public.
7. In assembly seating where guards in accordance with
Section 1025.14 are permitted and provided.
01-25-2011, 06:22 PM #4
01-25-2011, 07:18 PM #5
Re: Car Repair Pit
Nowadays, we know that used oil is carcinogenic, so it should be cleaned up. I remember scraping sludge off the floor of the pit at the local garage. We dripped a lot of oil in there.
01-25-2011, 07:49 PM #6
Re: Car Repair Pit
If I was that homeowner I'd consider selling that space off for burials.
01-25-2011, 07:54 PM #7
01-25-2011, 09:33 PM #8
01-25-2011, 09:44 PM #9
01-26-2011, 11:13 AM #10
Re: Car Repair Pit
Good Start on a First Class Fall Out Shelter.
01-26-2011, 05:00 PM #11
Re: Car Repair Pit
Install heavy plank cover and use for a wine cellar?
01-26-2011, 05:56 PM #12
Re: Car Repair Pit
great place to store explosive gas fumes!
01-27-2011, 11:27 AM #13
01-29-2011, 10:42 AM #14
Re: Car Repair Pit
