Thread: Column - support area
10-14-2011, 04:20 AM #1
Is this correct?
I would have preferred the brick to be laying on the wide side but other than a wooden shim, Is there a minimum bearing area for column support? Can a brick be used in this manner?
Are there any code issues with this set up?
10-14-2011, 05:24 AM #2
Re: Column - support area
10-14-2011, 07:16 AM #3
Scott,
Originally Posted by Scott Patterson
Your answer got my interest, so I tried to look it up in the code and in doing so I also found the answer to my own question.
BOTTOM LINE - The brick on its side AND as Scott stated the hollow block is not correct.
Here's what I found for anyones interest ...
"IRC 2009 R606.14 Beam Supports"
"Beams Girters or other concentrated loads supported by a wall or column shall have a bearing of at least 3 inches in length measured parallel to the beam upon solid masonry not less than 4 inches in thickness, or upon a metal bearing plate or adequate design and dimensions to distribute the load safely, or upon a continuous reinforced masonry member projecting not less than 4 inches from the face of the wall."
10-14-2011, 01:21 PM #4
That to me is a pier and falls under R606.6 Piers. and would need to have the cellular spaces filled solid not to mention the blocks laid in a stack bond which filling solid would answer that. It should also have an anchor attachment as part of it's continual load path.
The Kiln fire brick would maybe have a psi of 1200 and is designed as a veneer to withstand its own weight within that wall design. If a CMU filled with type M is 3000 psi and meets the the code for most 2 story residential constructed walls, theres no way that little brick is.
Joseph Ehrhardt
Building Forensic Specialist LLC
10-14-2011, 01:41 PM #5
Joe,
Interesting - Thanks.
Now that you have tangled this web - what is the defference between a pier and a column?
10-14-2011, 02:06 PM #6
Your welcome Ken...
under the Dictionary of Architecture 3rd addition;
column 1. In structures, a relatively long , slender structural compression member such as a post, pillar, or strut; usually vertical,supporting a load which acts in (or near) the direction of its longitudinal axis 2. in classical architecture, a cylindrical support consisting of a base (except in Greek Doric), shaft, and capital; eithe monolithic or built up of drums the full diameter of the shaft. 3 A pillar standing alone as a monument.
pier 1. A column designed to support concentrated load. 2. A member, usually in the form of a thickened section, which forms an integral part of a wall; usually placed at intervals along the concentrated vertical loads.
I would say "in my proffesional opinion" its non decorative, supporting a concentrated load in the crawlspace= a pier....but wait, if you wrote all the names on it of who is screwing us in our own country... would it then become a pillar standing alone as a monument= column???
Joseph Ehrhardt
