Results 1 to 9 of 9
    New Mexico
    Default Classy Beam Work
    It's why we have jobs, I guess.
    Jul 2010
    Wisconsin
    Default Re: Classy Beam Work
    What??? You don't care for the rustic look...
    Oct 2010
    Southwest US
    At least the post is below the joint (sort of).
    I'm guessing that's going to be a straw bale house.
    END GLOBAL WHINING
    New Mexico
    Wow, you are really good. This is a straw bale house, although this is outside on the front deck. This was my first straw bale house inspection. Not too different from a regular house at this point, but pretty cool build. The house was built at the end of the 90's.
    Cape Cod, Massachusetts
    The way the roof is framed it looks like that beam is a collar tie that is not continuous. From the picture you have posted, that looks more of a problem than the column support.
    Ken Amelin
    www.midcapehomeinspection.com
    Darrel Hood's Avatar
    Darrel Hood Guest
    I am curious to know what you identified to the client as problematic.
    Dang, "cut it 4 times and it is still to short".
    Then sent the new guy to the truck to get the wood stretcher. Told him to keep looking till he found it.
    Aug 2012
    Rock Hill S.C.
    Quote Originally Posted by Darrel Hood View Post
    Beam connection, attachment to column, exposed OSB...is my guess for starters.
    Oct 2010
    Southwest US
    looks to me like the beam is hanging over the edge of the post by an inch or 2 which also makes me think the posts are not lined up.
    Jim,
    It just looks like typical post and beam framing for straw bale infill. I thought "under construction" due to the unfinished look, exposed OSB, etc.
    I kind of enjoyed the first straw bale home I inspected. After the second, I vowed to never inspect another one.
    There seems to be no real standards or even agreement on how to build, particularly on whether the exterior stucco should be sealed or "allowed to breathe". I have seen both and one or the other is most likely wrong, but I don't know which. I would say many of these homes are going to have serious problems down the road if they don't already.
    END GLOBAL WHINING
