Thread: Lintel and mortar type
07-30-2013, 12:34 PM #1
07-30-2013, 01:18 PM #2
Re: Lintel and mortar type
Not normally a DIY type job.
I would call a mason.
The lentil may (or may not) need to be replaced.
07-30-2013, 01:52 PM #3
Is this lintel on the south exposure? Expansion/contraction of brick?
And possible water issues. Wind driven rain, no gutters, clogged gutters ... spilling water against the area in question.
07-30-2013, 02:17 PM #4
Also, I believe the lintel should extend 6" either side of the opening for proper bearing. If it's less; such as only 2-3" the lintel may have shifted. Also freeze thaw action on lintel..
08-02-2013, 07:06 PM #5
I don't think she's talking about beans, eh?The lentil may (or may not) need to be replaced.
- - - Updated - - -
08-03-2013, 03:02 PM #6
08-03-2013, 03:52 PM #7
Pictures are always helpful. Painting the exposed lintel will not help much with rusting. The stuff you cannot see is causing the problems with the cracking mortar. Assuming the lintel does not need replacement you need to re-point using the same type of mortar that was originally used or something with a lower compression strength. Using the wrong mortar can damage the brick.
You might want to get a guy who really knows tuckpointing to tell you what type of mortar to use or somebody told me you can send a sample somewhere to give you an analysis but I do not know where.
Just about everything you might want to know about brick can be found at the Brick Institute which has free technical notes.
Links to Technical Notes
08-03-2013, 04:00 PM #8
