    George2's Avatar
    George2 Guest
    Default Moisture Basement Wall
    What are the signs your basement walls may be retaining moisture. I have purchased a professional moisture meter and it does not show any abnormal reading but visually what should I look for that may be a clue. The home is brick veneer.
    New York
    Default Re: Moisture Basement Wall
    Look for mold/mildew or musty smell. Look for plastic sheeting under the drywall (it should not be there). Basements are designed to dry in.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    George
    What model and make of moisture meter did you purchase?
    Mark Parlee
    WWW.theBuildingConsultant.com
    EDI instructor, EIFS AMSV
    Nov 2011
    Houston, TX
    Quote Originally Posted by George2 View Post
    I am not very knowledgeable about basement moisture, but we have our moisture problems here in Houston. I find that measuring wood that is contact with the masonry is a more sure way to find moisture. Concrete can transmit moisture through pore channels which are difficult to find, and the moisture seems to diminish quickly after the wetting event. Moisture remains present in the wood much longer, and if you can find water-rot-deteriorated wood in contact with the masonry/concrete, you are boss.
    You can tape a 12 inch X 12 inch plastic sheet to the wall and see how much, if any, condensation occurs.
