Thread: Cracks through bricks
10-23-2007, 02:52 PM #1
10-23-2007, 03:13 PM #2
Re: Cracks through bricks
Cracked / broken bricks need replacement.
Defective grout needs tuck pointing.
I don't see any weeps in the soldier course.
10-23-2007, 03:52 PM #3
10-23-2007, 04:04 PM #4
While structural issues can cause damage to the bricks, the brick itself is a siding. No different than vinyl or wood siding.
If there were signs of settlement that could have caused this, a SE should be recommended. Did you know that metal can expand up to 7 times it's original size as it is allowed to rust in an area where the oxidization can not flake off, such as in a metal lintle.
The damaged brick does need repair as it is no longer water tight.
10-23-2007, 06:19 PM #5
10-23-2007, 09:12 PM #6
10-24-2007, 02:02 PM #7
10-26-2007, 06:46 PM #8
The amount of moisture brick will absorb when exposed to rain or snow depends on how it was fired. Brick intended for exterior applications will typically be fired longer, thereby increasing the water resistance. In cold climates, improper application of brick [such as an exterior application of brick intended for interior use] can result in serious problems.
However, this particular situation requires dealing with the underlying cause of the failure of the mortar bond and the cracked brick. Cracks at the mortar bond are less serious than cracked brick veneer. The underlying cause of movement must be addressed, in order for the repair to take. Chances are good that the steel lintel was improperly installed.
One option would be to write it as repair needed, and leave it to the builder or contractor to do it right. Unfortunately, that may be very expensive in this particular situation. The positive side is that your client is getting their money's worth from the inspection.
Randall Aldering GHI BAOM MSM
Housesmithe Inspection
www.housesmithe.com
