Thread: Nails in foundation
10-29-2007, 12:31 PM #1
Nails in foundation
10-29-2007, 03:53 PM #2
Re: Nails in foundation
I wouldn't think the nails are causing any problems other than asthetics (nails are visible [and ugly] and causing rust stains). I wouldn't comment on them in the report.
Bruce Breedlove
www.avaloninspection.com
10-29-2007, 04:33 PM #3
To save time from having to comment on it on the report and spend 10 minutes with the buyer about them and then listen to the agent yak about them, I just take a hammer and whack them flush with the foundation.
I have pulled out my bolt-cutters and cut the nails off depending how much time I had left.
Years ago I didn't give them much thought, then after dragging my ankle against one while leaning over to look at a condensing unit I thought different about those rusty nails.
10-29-2007, 04:39 PM #4
I've never seen this condition, but won't those suckers rust, expand, and pop off chunks of 'crete?
10-29-2007, 04:57 PM #5
Exposed nails, form ties, etc show a sloppy builder so with that in mind it may be wise to go into overdrive on your inspection. Remember, ever little detail is a clue in itself.
10-29-2007, 05:05 PM #6
You sure your not looking at the form ties? Dosen't matter these shoild be cut off also, but sealed as well.
