Results 1 to 13 of 13
    cory nystul's Avatar
    cory nystul Guest
    Default What is this? and 2x6 for supports
    I was in a crawlspace and came across this white powdery looking substance today. It was found only on the cement that was not covered by vapor barrier. Any ideas what it is?
    Second just for my clarification 2x6 are not acceptable for supports correct? This crawlspace was roughly 50% 4x6 and 50% 2x6.
    Orlando, FL
    Default Re: What is this? and 2x6 for supports
    The white deposits look like efflorescence, indicating moisture.
    The "piers" are wrong, look like temporary supports or added to offset floor bounce.
    Dom.
    I'm pretty sure the smallest wooden post that should be used is a 6x6, I don't have time to look it up but I'm about 99% sure. Also it needs to be treated wood and needs to have a concrete footing.
    The white crystalline material could also be left over mold treatment(boric acid based treatment), but with that big of a pile I doubt that is what it is. What Dom said is mor logical....
    Chicago IL
    Unless there is some major load on the floor the 2x6 support should be fine. However the installation method isn't.
    - does not appear to be attached at the top or bottom
    - appears to be angled instead of vertically straight
    - combine the angle, lack of attachment, floor movement, expansion, contraction, etc and the stud could come loose at some point and just fall over; then the floor starts bouncing again
    - looks like you should also be concentrating on moisture levels and ventilation concerns for that crawl
    - Oregon I'm assuming cold in winter so lack of insulation is another concern
    - any critter droppings in there, always want to mention those to the client
    www.aic-chicago.com
    "Cement" is the product that builders add to gravel and sand to make "concrete". So unless it is still in a bag, call it concrete.
    Sometiomes people will slam in a temporary pier like that to take spring out of the joist. This is done in dining rooms to stop glasses from tinkling when overweight people walk around the table, or in living rooms to support a piano.
    So first, look at the span of the joist without the pier to see if that pier is required or just an added crutch.
    Then recommend a proper post on a concrete footing. I have been told the seller simply removed his crummy post. Good, because it wasn't needed and could have become a highway for termites.
    Mar 2008
    Charlotte NC
    Looks more like a support for a broken joist! Pretty big crack in the center of that joist.
    And, unless you are actually buying "cement", even the bag with be labeled "concrete" mix.
    Vern, you need a bigger monitor. There's a check in the wood but it is not split.
    2 x 6 joists are a poor choice for a floor. It needs a good post. It's a mess, no doubt.
    Mar 2008
    Charlotte NC
    Odd that the supplemental support would be directly under that check, don't you think?
    I'm looking at it on my phone and I see the crack - look at the far right side of the photo where the beam ends at the edge of the photo.
    Mar 2008
    Charlotte NC
    Actually the line at the right side is a wire. The crack is in the center of the wood, not all the way through to the edge but a sign of possible stress and most likely loss of strength.
    Looking at it on my computer and ... you are correct - oops, not a crack.
    Sorry I thought you were seeing the wire as a split. Because I saw it too.
