Results 1 to 3 of 3
10-21-2016, 08:22 AM #1
CMU Founation - Inward Displacement - Repair / Brace or Replace
While I do not make it a practice of specifying how a foundation needs to be repaired, I am curious what guidelines you guys, and or professional contractors, may be using to decide when a block wall can no longer be braced, and will likely need to be rebuilt? Basically trying to decide at what point I need to start letting a potential buyer know that the wall may be past the point at which bracing (which is very common around this area) is a viable option.
On the same subject, how much inward displacement in a block wall is acceptable (bracing not necessary) if the underlying causes (grading, gutters / downspouts, etc.) have been taken care of?
10-31-2016, 06:46 PM #2
11-01-2016, 04:35 AM #3
Re: CMU Founation - Inward Displacement - Repair / Brace or Replace
