Results 1 to 10 of 10
    Colorado Springs, CO
    Default Odd Infill Roof Framing
    This is new construction. The infill framing where a gable ties into the main roof was framed with rafters and a ridge board. The framers added numerous 2X4 posts along the rafters down to the roof decking below (above the trusses). The posts were nailed to the rafters (2 nails) and toenailed (2 nails) to the decking. The bottoms of the posts are squared off (not cut to match the slope of the decking).
    Apparently this framing was passed by the local building inspector. I don't see the need for the posts. Plus I doubt the underlying trusses were designed for the additional point loads of these posts.
    How would you report this?
    Bruce Breedlove
    www.avaloninspection.com
    Aaron Miller's Avatar
    Aaron Miller Guest
    Default Re: Odd Infill Roof Framing
    Bruce:
    Green tagged I assume? How about IRC 301.1 and 801.2?
    Aaron
    Aaron,
    Both those codes pertain to design. I have the following limitation in my report: "ยท Engineering or architectural services such as calculation of structural capacities, adequacy, or integrity are not part of a home inspection." I'm not concerned about the rafters so much as the trusses below that are being loaded with point loads that I suspect the truss manufacturer did not design for.
    Would you recommend the builder provide documentation that the trusses can accomodate the point loads from these posts?
    Bruce Breedlove
    Aaron Miller Guest
    Bruce:
    Certainly.
    Aaron
    That's exactly what I did.
    Bruce Breedlove
    Wonder if the framer knows he left all the 'temporary' bracing up?
    Yeah, that a definite 'Have a structural engineer verify ... '
    Interesting. I had not thought of that.
    Bruce Breedlove
    charles buell's Avatar
    charles buell Guest
    I have to say that the "forest" of supports whether temporary or intended to be permanent really doesn’t load the area of infill any more than any properly in-filled area. These T or L shaped houses often have one roof laying over the top of the other roof and the lapping area is merely in-filled and the adjacent roof carries the load of the in-filled area. You could argue that the forest of posts helps spread the load but I really don’t see how it creates any structural concern. That said the adjacent roof trusses have to have been designed for the adjacent roof overlay----and you will rarely see any design change in the adjacent roof trusses to compensate for a "typical" overlay
    Last edited by charles buell; 12-22-2007 at 11:54 AM. Reason: put words in quotes wrong
    Quote Originally Posted by charles buell View Post
    That's it exactly. The underlying trusses will see roughly the same loads as they would without the overlying roof (plus the dead load of that overlying roof structure). BUT, instead of the loads being distributed over the roof surface, these loads have been converted to point loads on the trusses. Trusses typically must be designed for point loads such as this.
    That said, I doubt the infill framing will overstress the top chords of the underlying trusses. But that is not a call that I want to make.
    Bruce Breedlove
    I have to say that the "forest" of supports ...
    I see I'm not the only one who thought of that as a "forest" ...
    My thought was 'My gawd, that framer can't see the forest for the trees.'
