Results 1 to 9 of 9
    Connecticut
    Default Garage door header
    Doubled 2x18 glue lam. 20 foot span. Same as in the approved plans. Deflection of 5/8 inches over that span.
    Center section under poor doorhead flashing is wet and could dig in 3/4 inch with Awl.
    Soft over the center 4 feet or so.
    Sag noted at exterior blocked trim which has opened at blocked joints.
    Any thoughts on the degree of deflection.
    We have a SE coming but I was wondering what you guys think.
    Thanks, Wayne
    Default Re: Garage door header
    Thanks, Wayne
    All right what have you done with the REAL WAYNE ! ( aka. old Silver Back )
    All I can say whoever you are It,s a Goner.
    Healdsburg, CA
    Tell the SE to hurry!
    Ron Bibler's Avatar
    Ron Bibler Guest
    Remove and replace. "INKIND".
    Best
    Ron
    Connecticut
    That's good Billy, Got tierd of looking at the same old Monkey. Thats a pic of my home in Thailand where I should be RIGHT NOW!!!
    Thanks guys, That was my interpretation in a few more well picked words I might add. Contractors already 250 grand in the bag with more to go.
    Ooooo many , many, Baht.
    You going to let him up anytime soon ?
    Lancaster, CA
    Apr 2007
    gainesville fl
    Tell them not to forget the Z flashing this time.
    Connecticut
    This was fixed a month ago. Had the SE go out and concurred that the beam was affected by the leak and would require replacment. Contractor was pissed as usual, which means I did my job. The flashing problem was due to the designer insisting on a trim block in the center of each door head that made the flashing a little more difficult and apparently more than the brain surgeon could handle.
