Results 1 to 9 of 9
Thread: Garage door header
05-31-2008, 03:48 PM #1
Garage door header
Doubled 2x18 glue lam. 20 foot span. Same as in the approved plans. Deflection of 5/8 inches over that span.
Center section under poor doorhead flashing is wet and could dig in 3/4 inch with Awl.
Soft over the center 4 feet or so.
Sag noted at exterior blocked trim which has opened at blocked joints.
Any thoughts on the degree of deflection.
We have a SE coming but I was wondering what you guys think.
Thanks, Wayne
05-31-2008, 04:11 PM #2
Re: Garage door header
05-31-2008, 04:25 PM #3
Tell the SE to hurry!
05-31-2008, 04:48 PM #4
Remove and replace. "INKIND".
Best
Ron
05-31-2008, 06:06 PM #5
That's good Billy, Got tierd of looking at the same old Monkey. Thats a pic of my home in Thailand where I should be RIGHT NOW!!!
Thanks guys, That was my interpretation in a few more well picked words I might add. Contractors already 250 grand in the bag with more to go.
05-31-2008, 06:36 PM #6
07-13-2008, 10:33 PM #7
Did it fall down yet.
07-14-2008, 02:28 AM #8
Tell them not to forget the Z flashing this time.
07-14-2008, 05:33 AM #9
This was fixed a month ago. Had the SE go out and concurred that the beam was affected by the leak and would require replacment. Contractor was pissed as usual, which means I did my job. The flashing problem was due to the designer insisting on a trim block in the center of each door head that made the flashing a little more difficult and apparently more than the brain surgeon could handle.
