Re: alternating joist sizes
John,
It appears to me that the larger floor joists are boards of actual dimmension. They used to ese rough cut boards and a 2X4 would actually be 2" X 4". Now they are planed to provide a more smooth surface and the resulting 2x4 is now 1-1/2" X 3-1/2". The home may have been built with the "rough cut" lumber then additional joists added for additional support as the rough joists appear to be spaced about 24" and the standard joists put the spacing somewhere around 12" (according to my view of your picture).
In the photo that you provided it isn't very clear, but it appears that the smaller joists may not be supported at the sill plate. My biggest concern would be insufficient end support for those joists. After that, the PVC does not appear to have sufficient support.
The smaller joists in the other area may be due to the addition being built at a different time and that was what was available.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
