LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 05-31-2007, 10:37 AM
John Arnold John Arnold is offline
crack of the month
Older structural brick - not veneer. Can't really see the lateral displacement and bulging so well in the photos. This is the worst I've seen in quite a while. Not sure how to fix, but then that's not my job.
Old 05-31-2007, 11:10 AM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: crack of the month
It's already been repaired. See the earthquake rod? That will hold the brick in place (i.e., keep the brick from moving out on this and the opposite face). Earthquake rods installed perpendicular to this one will help keep this crack from widening.
Actually, while earthquake rods are a big improvement they are not the final solution. I remember seeing earthquake rods on many old brick buildings in Charleston. Not sure how effective they are in a large earthquake but they were probably cutting-edge techology in earthquake-proofing buildings circa 1890.
Bruce Breedlove
www.avaloninspection.com
Old 05-31-2007, 11:39 AM
David Banks David Banks is offline
Scroll down to Bulging of walls.
Above-ground masonry walls - Oldhouseweb.com
Dave
Old 05-31-2007, 11:50 AM
Nick Ostrowski Nick Ostrowski is offline
I think the cause of that crack is quite apparent.........that pen is forcing the wall apart. If you remove the pen, everything should go back to normal .
Old 05-31-2007, 12:20 PM
Nick - You know what they say: the pen is mightier than the ... star anchor?
  #6 (permalink)
Old 05-31-2007, 12:27 PM
We never called them "earthquake rods", but installed them to help retain the outer wythe of brick walls on a few older homes. We simply called them tie backs and stars anchors.
I like the explanation given in the link David provided, but settlement can also cause variations of that bulging.
  #7 (permalink)
Old 05-31-2007, 01:15 PM
My response was about 90% tongue-in-cheek.
Bruce Breedlove
  #8 (permalink)
Old 05-31-2007, 02:15 PM
Quote:
In Gainesville, Florida, we had some old brick structures, many had those tie backs and stars installed to retain the brick walls from movement/bulging/etc.
Thus I did not make the 90% connection.
  #9 (permalink)
Old 05-31-2007, 06:34 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Sometimes the anchors work and sometimes they don't.
Eric Barker
Barrington, IL
  #10 (permalink)
Old 05-31-2007, 07:27 PM
Quote:
Yep. I've seen that too.
  #11 (permalink)
Old 05-31-2007, 08:23 PM
Thom Walker's Avatar
The engineer agreed this crack did not need repairs.
- Paul Fix
  #12 (permalink)
Old 05-31-2007, 08:28 PM
James Duffin James Duffin is offline
Yep....don't need repair but sure needs me!
  #13 (permalink)
Old 06-01-2007, 05:42 PM
Jon Randolph Jon Randolph is offline
Correct me if I am wrong, but with that wall type, shouldn't there be cross ties every 6 rows?
By the way, Thom, would advise to cover and hide that crack. Major safety concern.
"In the news today, an amish waoman and her 6 childred died when the husband (father) veered his carriage into traffic while looking at a road side sign. Man survived, but is said to be going blind."
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Home inspection
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/structural-components-home-inspection-commercial-inspection/1355-crack-month.html
Posted By For Type Date
components: Blogs, Photos, Videos and more on Technorati This thread Refback 05-31-2007 01:22 PM
Similar Threads
Crack in foundation Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 15 05-22-2007 12:15 PM
May Is National Electrical Safety Month: Brian Hannigan Electrical Systems: Home Inspection and Commercial Inspection 0 05-10-2007 09:28 AM
May is Deck Safety Month Brian Hannigan Exterior Systems: Home Inspection and Commercial Inspection 2 05-02-2007 05:32 AM
Crack in the wall Mike Huppi Building Interior: Home Inspection and Commercial Inspection 17 04-18-2007 11:44 AM
caulk that crack says SE John Arnold Structural Components: Home Inspection and Commercial Inspection 6 04-12-2007 01:33 PM
vB.Sponsors
Ad Management by RedTyger
