Old 06-02-2007, 08:42 AM
dan orourke dan orourke is offline
Gutter discharge
Old 06-02-2007, 09:34 AM
Ed Ochs's Avatar
Ed Ochs Ed Ochs is offline
Re: Gutter discharge
Dan,
This downspout is a bigger problem than having another 90 to help it shed water (right now it will push under shingles) so to answer your question yes bad idea...even better would be to get downspout to terminate in that lower gutter for discharge
Old 06-02-2007, 06:06 PM
Jon Randolph Jon Randolph is offline
The roofing will wear quicker in that area as the increased and concentrated ater flow will dislodge the granules more quickly. Also as Ed stated, the water could be directed under the adjacent shingles. Better to discharge the water to the downspout below, or even better to the ground.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Old 06-02-2007, 06:32 PM
Thom Walker's Avatar
I would guess that if that is an upside down shingle placed there, that a leak was already detected. It appears that no kick out flashing was employed. And did the siding come into contact with the shingles or were you looking at flashing along that wall.
I'm not aware of code addressing this specific issue. R801.3 addresses general roof drainage, which this house may not have met either. I don't know the soil type based on this picture, but if it is expansive or collapsible soil, that downspout pictured should have termiinated at least 5 feet away from the building.
Re: that 90, turn it around. I'm npt seein any pitch on the gutter. Was there?
- Paul Fix
Old 06-02-2007, 07:43 PM
James Duffin James Duffin is offline
I always suggest that a metal splash diverter be installed to minimize deterioration to the roof surface where the gutter dumps on a roof surface. It is considered an improvement and nobody does it but I think it is a good idea.
  #6 (permalink)
Old 06-04-2007, 08:17 AM
Robert Schenck's Avatar
Robert Schenck Robert Schenck is offline
I see a lot of this myself. Although I don't know of any "Code" requirement for the builder to bring the downspout to the gutter, I always recommend to the buyer to bring it down to the gutter to prevent premature wear on the shingles.
Robert
Roberts Home Inspection Service
Home inspection
Similar Threads
Extra discharge pipe Scott Dana Plumbing System: Home Inspection and Commercial Inspection 12 05-25-2007 02:44 PM
vB.Sponsors
Ad Management by RedTyger
