Old 08-10-2009, 10:06 PM
Randall Clark Randall Clark is offline
brick movement
What typically causes brick to drop like at this corner? Just this upper corner above the roof - no issues below it.
IC Home Inspection Report Writing
Old 08-10-2009, 10:35 PM
Re: brick movement
Looks like lack of support and the flashing has probably compromised any structural integrity that was to be had.
Allen, Texas 75002
Old 08-11-2009, 04:48 AM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
Re: brick movement
Quote:
RC: As JL alluded to it is a structural issue. The support detail for brick-on-roof installation is one that is often botched by today's "carpenters".
Depending on the age of the home, whatever settlement is going to happen due to poor framing techniques, has happened. In my area the three 2X6s that should underly this mess are required to be pressure-treated material, lag-screwed as per the code. What I usually find is untreated material nailed into place. Sometimes they even leave out the steel angle.
Even if they used treated wood, that wood has a tendency to shrink more than the untreated lumber, thus causing movement over time. Combined with poorly fitting joints, a lot of movement can be experienced.
Repair of the bricks and flashing should make things look better, assuming you don't hire someone from the original builder or contractor.
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
Old 08-11-2009, 05:38 AM
Raymond Wand Raymond Wand is online now
Re: brick movement
Randall
Is this a double brick house?
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
Old 08-11-2009, 04:52 PM
Steve Frederickson Steve Frederickson is offline
Re: brick movement
If those bricks don't extend all of the way down to the foundation, but instead bear on a wood header below the roof/wall line, then my guess would be possible rot in the header. It looks like the flashing is newer, and the roof leader discharges in the immediate area, so rot would be a possibility.
If the brick extends down to the foundation, and there are no cracks in the foundation below this area, my next guess would be lack of expansion joints in the brick (which is rarely a problem in relatively small houses).
Are there cracks on the interior in this area, any sign of water damage on the interior...?
  #6 (permalink)
Old 08-11-2009, 05:50 PM
Nick Ostrowski Nick Ostrowski is online now
Re: brick movement
That "flashing" is crap. Who know what you'll see when your peel that away.
  #7 (permalink)
Old 08-11-2009, 06:39 PM
Michael Garrity Michael Garrity is offline
Re: brick movement
[IMG]file:///C:/DOCUME%7E1/MICHAEL/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/MICHAEL/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]AD, I am looking at the picture in your post.What holds the steel angle in place on a steep slope?
  #8 (permalink)
Old 10-03-2009, 04:46 PM
Richard A Hetzel Richard A Hetzel is offline
Re: brick movement
Therer used to be a clause in the building code that required masonry to be supported on either steel or masonry. Brick supported by wood would not have conformed. If that clause is no longer in the code, whoever took it out should fall victim to a masonry collapse.
  #9 (permalink)
Old 10-03-2009, 07:32 PM
Richard Pultar Richard Pultar is offline
Re: brick movement
gravity
  #10 (permalink)
Old 10-04-2009, 08:19 AM
Re: brick movement
Quote:
MG: A steel angle lag-screwed to the underlying 2X6s.
  #11 (permalink)
Old 10-04-2009, 01:52 PM
Ron Bibler's Avatar
Ron Bibler Ron Bibler is offline
Re: brick movement
Steve and Aaron have very good points. We see condition like this all the time out in California. bad Installations from the 50s 60s and even up to date. No bottom supports for the veneer.
Santa Rosa California Home Inspection - Exterminating & Thermal Imaging
Best
Ron
  #12 (permalink)
Old 10-04-2009, 01:57 PM
Re: brick movement
Randal did not answer the question whether this is a double brick home or whether its a newer brick veneer with reclaimed brick.
This damage may have been caused by improper roof water management spilling in this area and freeze thaw cycles.
  #13 (permalink)
Old 10-04-2009, 02:01 PM
Ron Bibler's Avatar
Re: brick movement
From what I can see in the photo its a Face Veneer. Look at the door opening.
Best
Ron
  #14 (permalink)
Old 10-04-2009, 03:32 PM
Re: brick movement
Thanks for all of the replies. It is veneer on a 2-yr old home. Buyer had it repaired although I do not know how it was done.
  #15 (permalink)
Old 10-04-2009, 07:42 PM
Re: brick movement
If it were built with the steel angle as pictured a few psots back, it's possible that the bond between mortar and steel gave way, and that the bricks simply slid down the steel angle slightly, which would have produced the effect shown. The veneer ties would have prevented a total collapse, but might have allowed enough lateral movement to cause the pictured damage.
  #16 (permalink)
Old 10-06-2009, 03:24 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Re: brick movement
That brick veneer was broke from trying to drive a masonry nail in the mortar joint. Not much meat to bare the blunt force of driving a nail. Broke several of those corner myself over the years.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Similar Threads
Chimney movement Reis Pearson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 8 11-03-2008 03:21 PM
What is with all the red brick Ron Bibler Tools and Equipment 1 04-21-2008 05:46 AM
Brick Mortar? Rick Hurst Building Envelope: Home Inspection and Commercial Inspection 9 04-09-2008 02:29 PM
brick chimneys daniel nantell Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 04-08-2008 04:20 AM
Brick David Banks Building Envelope: Home Inspection and Commercial Inspection 5 05-19-2007 06:06 PM
vB.Sponsors
Ad Management by RedTyger
