LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 06-08-2007, 06:41 PM
dan orourke dan orourke is offline
a problem or not
Old 06-08-2007, 07:27 PM
Nick Ostrowski Nick Ostrowski is offline
Re: a problem or not
Looks like crumbled stucco coating on a stacked stone foundations wall to me.
Old 06-08-2007, 07:30 PM
Jim Luttrall Jim Luttrall is online now
Yes it is a problem. Repairs are needed.
It APPEARS to be a slab foundation with rebar too close to the exterior that has begun to rust and pop the concrete off. There may be a parge coat that is flaking off.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 06-08-2007, 08:33 PM
Thom Walker's Avatar
Quote:
Originally Posted by dan orourke View Post
should a structural engineer look at it or would a foundation company suffice?
Depends. What was the rest of the structure like. If this was an anomaly and there were no other signs of stress, as in other crumbling areas of the foundation, interior wall cracks, unsquare doors and windows, evidence of standing water, reversed grade, then I would recommend a qualified foundation contractor.
If the building is new, I would recommend having the builder contacted first.
Everybody has his own style, but I try to finish the entire structural inspection before writing the opinion on the foundation. That helps me decide if I'm going to call for a State licensed structural engineer. I've always though it was stupid to have the foundation listed first on the TEXAS mandated form. Evidence of a failed foundation is found many other places that the foundation itself.
- Paul Fix
Old 06-08-2007, 09:21 PM
Any decent foundation company will have their own structural engineer, either on staff or one they work with regularly.
  #6 (permalink)
Old 06-09-2007, 03:43 AM
Ah, I see the rebar now.
  #7 (permalink)
Old 06-12-2007, 11:01 AM
Richard Rushing's Avatar
Folks, anytime rebar is exposed it is suceptable to rust and should be repaired.
Richard
Richard Rushing, HCRI
Duncanville, Tx.
  #8 (permalink)
Old 06-12-2007, 11:18 AM
Quote:
Richard
And a "proper" repair is not as easy as it may first seem.
  #9 (permalink)
Old 06-12-2007, 02:22 PM
Folks, anytime rebar is exposed it is suceptable to rust and should be repaired.Richard
That's a given. The question became, "Does it need the opinion of an SE or not? I still say, that in the absence of other evidence of structural damage, that calling for an SE is pushing the CYA button too fast. I think recommending that the damaged area is completely inspected by a qualified foundation Company is the first best step. As Jerry mentioned, any reputable foundation company is going to be affiliated with an SE. If, when they chip away all that broken crap that we're not allowed to remove and inspect the rebar, they should be able to determine if it's going to be a permitted repair requiring a structural engineer's review or a patch.
I think what we would all want is to be sure that Uncle Bob doesn't come over with his premix and slap a cover over it. Now, if outside that little perspective we can all see in Dan's picture, Dan sees other structural evidence; or if he comes across other structural issues unrelated to this, but in need of SE attention, that's a different story.
What other structural stuff was there, Dan?
- Paul Fix
  #10 (permalink)
Old 06-12-2007, 04:32 PM
wayne soper's Avatar
were there weep holes? Looks like moisture in the concrete froze and blew the potion out but the inherant problem would be in the weep hole question.
  #11 (permalink)
Old 06-12-2007, 05:04 PM
Terry Neyedli Terry Neyedli is offline
thoughts on this photo? problem or not?
Problem! Potentially yes.
Further evaluation required. Time study has/should be performed. Check for other areas for water intrusion same/similar conditions. It may work into a large dollar if not taken care of promptly.
T.Neyedli
www.alphahomeinspections.ca
  #12 (permalink)
Old 06-12-2007, 05:54 PM
Quote:
Terry,
There *IS* a problem with it, now, not "potentially".
I'll be kind (I see you've only made 7 posts) and let some others here address why HIs do not need to state "further evaluation" and why it makes the HI look like they are wimping out.
Time for what? For it to rust more and spall more? You want us to wait until the cost goes up even more than it is now? And to wait until after closing?
It IS a problem NOW. Address it NOW.
  #13 (permalink)
Old 06-12-2007, 06:15 PM
The (initial thread) question by Dan O. was:
"thoughts on this photo? problem or not?"
My statement was a direct answer to the question presented-- Yes... it is a problem. I do agree with your statement (Thom): "I think recommending that the damaged area is completely inspected by a qualified foundation Company is the first best step."
Just so that we are clear to anyone who is reading this thread, ANYTIME you see exposed rebar, it's a repair item-- not sometimes. The extent of the repairs are dictated by the severity of the issue. Some are much greater than others and will require a structural engineer. However, I just don't recommend a PE for a repair job that can be done by a (reputable) foundation company.
Rich
Duncanville, Tx.
  #14 (permalink)
Old 06-12-2007, 06:21 PM
Agreed.
- Paul Fix
  #15 (permalink)
Old 06-12-2007, 06:53 PM
Jack Feldmann's Avatar
Jack Feldmann Jack Feldmann is offline
Jerry said, "I'll be kind (I see you've only made 7 posts) and let some others here address why HIs do not need to state "further evaluation" and why it makes the HI look like they are wimping out."
I agree that there are many times that inspectors say "get this evaluated, when they really should be saying, "this thing needs repair".
However, in the case of fireplaces and chimneys I do sometimes tell my clients they need to be evaluated, simply because I wasn't able to look up the flue, view the crown, or look down the flue. There may not be anything wrong, but because of the age of the house, it would be a good idea to have it checked out by a professional.
By the way, to me, wimping out is calling for an expert or engineer at every drop of a hat.
  #16 (permalink)
Old 06-12-2007, 07:23 PM
Quote:
Me too, that's what "further evaluation" is.
"However, in the case of fireplaces and chimneys I do sometimes tell my clients they need to be evaluated ... "
You do it a lot, you say?
  #17 (permalink)
Old 06-18-2007, 02:40 PM
Frank Bombardiere Frank Bombardiere is offline
Dan, was there a leaking shower pan on the other side of that wall. Looks like the moisture came from inside to me. I would try to find out if there is some sort of leak behind that wall, and I would call out that the foundation needs to be repaired by a qualified foundation repair contractor.
  #18 (permalink)
Old 06-18-2007, 02:59 PM
neal lewis neal lewis is offline
If, when they chip away all that broken crap that we're not allowed to remove and inspect the rebar...
Thom, maybe it's a Texas thing, but are you really NOT ALLOWED to do a little digging/damage?
  #19 (permalink)
Old 06-18-2007, 07:56 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is online now
I recommend that a qualified foundation contractor, who utilizes the services of a licensed engineer to design repairs, be contacted to determine all needed repairs & best repair methods, tp estimate costs, and to perform any repairs deemed necessary.
Erby Crofutt, Georgetown, KY
B4U Close Home Inspections & Radon Testing
www.b4uclose.com www.kentuckyradon.com
  #20 (permalink)
Old 06-18-2007, 08:28 PM
Quote:
