Old 10-08-2009, 06:23 PM
mathew stouffer mathew stouffer is offline
Deck support
I found this in a garage with a flat deck above it. It looks like a piece of angle iron bolted to the glue lam and foundatoin. Any thoughts on the installation.
Old 10-08-2009, 06:54 PM
wayne soper's Avatar
Re: Deck support
Dosen't look good. Why? A solid post installed in the same place would have taken up 2 more inches and no problem. Thats alot of work to end up with what I would call an improper application even though it may last a long time with no problems.
That is non pro, or mabey semi pro, yeah, semi pro
Old 10-08-2009, 06:59 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: Deck support
Quote:
Originally Posted by mathew stouffer View Post
I
Home Made.
Billy J. Stephens HI Service
Old 10-08-2009, 07:27 PM
Re: Deck support
It was crazy, the whole house was home made. I was getting overwhelmed, around each corner was some crazy configuration. Check some of these out. It is the first time I have seen a trap door installed on the return plenum
Old 10-08-2009, 08:05 PM
Re: Deck support
Unapproved ( Galvanized ) Connectors.
Not Properly Supported Ect.
  #6 (permalink)
Old 10-08-2009, 08:14 PM
Re: Deck support
Billy,
Check out the valves, I have never seen those on a manifold before.
  #7 (permalink)
Old 10-08-2009, 11:11 PM
Re: Deck support
All I can say is I'm glad it was you and not me
I hate houses like this. Everything is uncommon.... some of it works, some doesn't. Of course the first question when you call something out as incorrect is "How long until I need to replace it?" - followed closely by "how much is it going to cost?" - followed by "do you have the name of a contractor that can do it for me?"
This is really one of the biggest quandrys I run into in this job... something that is unconventional but is for the most part working. All the SOPs say I've done my job if it's working as inteneded. Every contractor that comes behind me will have a different idea of what MUST be done. The seller will sue me for saying it's wrong. The buyer will sue me for not saying it's wrong.
Sorry for the rant.... it's been a long week.
www.crawfordinspections.com
  #8 (permalink)
Old 10-09-2009, 08:30 AM
Re: Deck support
I hear you, it's a pain in the ass. All the systems worked well, BUT.
  #9 (permalink)
Old 10-09-2009, 08:31 AM
Wayne Carlisle Wayne Carlisle is offline
Re: Deck support
Quote:
Why are they unapproved? Galvanized fittings are allowed for water lines.
Also this looks like an approved header for PEX.
  #10 (permalink)
Old 10-09-2009, 08:44 AM
Scott Patterson's Avatar
Re: Deck support
PEX is not all that bad, those valves are common on that type of manifold. Yes, it could be supported a little more but.....
Is that trap door so that the air filter can be changed?
The untreated wood used for a support needs to go and looks like one of the bigger issues.
As for the deck support? I would note that it is an unconventional method of support and unconventional things tend to act in unconventional ways! I would then put in the typical engineer recommendation. But, my gut feeling is that it is fine...
Scott Patterson
  #11 (permalink)
Old 10-09-2009, 09:19 AM
Re: Deck support
Quote:
Are they Approved Connectors for Pex ?
  #12 (permalink)
Old 10-09-2009, 09:54 AM
Re: Deck support
Yep the door is for the air filter.
  #13 (permalink)
Old 10-09-2009, 12:32 PM
Robert Dalga's Avatar
Robert Dalga Robert Dalga is offline
Re: Deck support
Actually the angle iron post looks pretty good and appears to be well installed (i.e. well bolted to poured wall and beam). (A bit unusual for residential framing though). Looks like an engineering spec. Did you happen to see any deflection, sagging, etc. associated with it? I wouldn't have a problem with it if I didn't see any related issues (might just want to tell the clients to have it further evaluated by a specialist (i.e. engineer).
RJDalga
http://homeanalysts.com
Kalamazoo, MI
  #14 (permalink)
Old 10-09-2009, 01:22 PM
ben jacks ben jacks is online now
Re: Deck support
Hi Matt,
I agree with Scott and Robert's comments and would also ask if this is a two-car garage deck supported span using those three 2x10's. It looks like they additionally have floor joists with metal hangers teed into that 'header beam'. (Referring to Robert's note on possible unsupported mid-span deflection) rbj
  #15 (permalink)
Old 10-09-2009, 02:57 PM
Re: Deck support
There is a flat deck surface above the entire garage, yes it is a two car. The problem I have with it, is the area is North facing and the deck is flat. Very little sun in the winter and this area gets 400 to 500 inchs of snow a year. Moreover, all the snow from the metal roof slides onto the deck. So will it be able to handle the additional load. Doubt it, but is will be interesting to see
  #16 (permalink)
Old 10-09-2009, 03:25 PM
Re: Deck support
In Lake Tahoe that scenario would be questionable. There are snow-loading requirements for high country structures above a sunshine load that may need to be addressed in your area. I would check the AHJ snow loading requirements at that elevation and then compare the midspan support needed....for instance, a 16' standard garage door header in the flat lands minimum would be a 4x16 DF 2 or better.
An equivalent to that would be a 6x12 DF 2 or better. In high country, a 250 lb. sf load would be realistic for using at least a 6x14 DF minimum. Of course there are modern I-Joist and laminate trade-offs that are not evident here that would be worth checking out. rbj
  #17 (permalink)
Old 10-09-2009, 03:40 PM
Rod Butler Rod Butler is offline
Re: Deck support
A plywood return plenum next to the furnace? I assume it is a furnace. You may want to check for mfr's recommendation for combustible surfaces that close to the furnace.
  #18 (permalink)
Old 10-09-2009, 03:57 PM
Steve Frederickson Steve Frederickson is offline
Re: Deck support
The steel angle is obviously there to support the end of the beam, but the steel "post" might have been an attempt at bracing the foundation against lateral load. (see: PowerBrace.net - Foundation Wall Bracing Systems)
It looks like they might have cut a new opening in the wall and thought, for some reason, that the wall then needed bracing.
Also, looks like somebody took a chisel or jackhammer to the top corner of the foundation and the corner of the opening, maybe to make room for the LVL, which suggest they might have been repairing some rot damage to the sill?
We may never know...probably a homeowner with too much time on his hands
  #19 (permalink)
Old 10-09-2009, 04:06 PM
Re: Deck support
Quote:
Not to get too far off course as the can of worms opens further, this is an newer home and the energy requirements may still come into play...so there may be a minimum insulation required around the HVAC heat ducting that needs mention. rbj
  #20 (permalink)
Old 10-09-2009, 04:32 PM
Michael Schirmer Michael Schirmer is offline
Re: Deck support
Though it doesn't qualify as a column, I would say it's OK in that it's secured to the concrete wall.
  #21 (permalink)
Old 10-09-2009, 07:59 PM
Tom Rees Tom Rees is offline
Re: Deck support
We got off the subject of the deck support but here's a real beauty. All materials in one app. and yes that is polybutylene.
  #22 (permalink)
Old 10-10-2009, 10:07 AM
John Kogel's Avatar
John Kogel John Kogel is offline
Re: Deck support
Quote:
I would not say that or put that in writing, only a structural engineer can do that. Better to play it safe in this case. Recommend having it checked out.
  #23 (permalink)
Old 10-15-2009, 01:51 PM
Jeff Zehnder Jeff Zehnder is offline
Re: Deck support
Just a general Deck Question for the group??
What year (if any) were bolts required for the deck band joist against the home. Or asked another way when were lag bolts allowed instead of actual bolts and nuts to hold the deck band to the home???
Jeff Zehnder
Home Inspector, NC
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Similar Threads
Second story deck support Trent Tarter Exterior Systems: Home Inspection and Commercial Inspection 8 08-24-2009 10:30 AM
Ceiling Support Jerry McCarthy Structural Components: Home Inspection and Commercial Inspection 4 08-13-2009 09:51 PM
Enough support for deck and roof section? Brent Crouse Exterior Systems: Home Inspection and Commercial Inspection 11 05-19-2009 08:27 PM
Support for A/C Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 16 11-11-2007 12:46 PM
A new way to support a hip rafter Scott Patterson Attic Areas: Home Inspection and Commercial Inspection 5 10-02-2007 08:31 PM
vB.Sponsors
Ad Management by RedTyger
