Originally Posted by
Randall Clark
I-joist under floor framing. Wall above this pier is parallel to I-jiosts. Wood on top of pier rests against floor sheathing. With stick-built, I could think of a better way to do this but not completely sure with I-joists. So it this considered ok with I-joist framing?
Surely you jest.
No, it is not okay (nor is that electrical wire run across the bottom of the joist).
What should have been done, if there is a concentrated load at that location, is the installation of squash blocks in the existing joists, perpendicular joists installed between them and below the load, and a proper pier support up to that point, with a plate catching the existing joists and the perpendiculars.
Of course I wouldn't write that up in a report - instead just call it out as a defect to be repaired properly by a competent contractor.
