Share |
Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
The ASHI School
Old 03-15-2010, 02:56 PM
Jon mackay Jon mackay is offline
Post and Beam garage supports heaving
This garage construction is with main supports in the ground at an 8' spread and then concrete slab poured around the supports.
It appears that one of the supports has heaved upward 3 or 4 inches (see picture) and there is standing water at the left side support area at the exterior. The supports appear to be treated but they are absorbing water at several areas. The garage door is also falling apart I believe as a result of heaving.
My thought is that the supports should not be in the ground for this type of structure and that they are not likely driven down below the frost line (at least not at the heaved one)
I'm not sure what to call out as I don't come across post and beam very often.
Home inspection - The Cost Of Business.
Old 03-15-2010, 04:20 PM
Michael Garrity Michael Garrity is offline
Re: Post and Beam garage supports heaving
Pole barn construction.Are the posts PT wood?Hole maybe not deep enough.Dig a hole and find out.Not too difficult to fix.
Old 03-15-2010, 05:42 PM
The posts are pressure treated but if they are sitting in water wont they still rot?
So to fix, replace the post with one of the proper depth?
Old 03-15-2010, 06:22 PM
Maybe the wrong type of PT.Different types for different applications.Replace the post to the correct depth or cut the post, dig hole,sono tube,concrete,attach post to concrete.The second fix might require addition framing inside.
Old 03-15-2010, 06:25 PM
chris mcintyre's Avatar
chris mcintyre chris mcintyre is online now
Quote:
Depends on the grade. See page 4.
When I was younger I could remember anything, whether it happened or not. - Mark Twain
  #6 (permalink)
Old 03-15-2010, 08:21 PM
Ken Rowe's Avatar
Ken Rowe Ken Rowe is online now
This is what I'd say on the inspection report,
"It appears that one of the supports has heaved upward 3 or 4 inches (see picture) and there is standing water at the left side support area at the exterior. The supports appear to be treated but they are absorbing water at several areas. The garage door is also falling apart I believe as a result of heaving. Repairs are necessary by a qualified contractor".
Your job as an inspector is to document, report and refer (if necessary). Specifying repairs is not within the scope and will likely get you in trouble unless you're a PE or contractor yourself.
http://minnesotahomeinspectors.com/employment.html
BPG Inspection Services
ASHI #242887
  #7 (permalink)
Old 03-16-2010, 03:56 AM
Ken,
Thank you, that is exactly what I'm looking for.
It is hard to stay focused on inspecting sometimes and not try to help figure out what the repair should be.
The fact is, the problem has been identified, now time for a specialist to give it the attention it deserves and figure out the repairs. As much as I would like to figure everything out, it goes far beyond scope.
Very helpful!!
  #8 (permalink)
Old 03-16-2010, 07:18 AM
Ken Rowe's Avatar
Ken,
I totally agree.
ASHI #242887
United Infrared
The ASHI School
Share |
Similar Threads
Steel I beam and telescope post related questions Yufei Shi Structural Components: Home Inspection and Commercial Inspection 15 08-14-2009 02:44 PM
Code for pier (or post) & beam? Terry Beck Sub-Structure: Home Inspection and Commercial Inspection 3 04-14-2009 09:38 AM
garage door light beam sensor, safety reverse Ron Bishop Exterior Systems: Home Inspection and Commercial Inspection 3 01-20-2009 05:34 PM
Post Your Problems: Inspect home inspector's credentials - Pittsburgh Post Gazette Brian Hannigan Associations, Ethics, Standards, Licensing, Legislation:Home Inspectors & Commercial Inspectors 0 08-05-2008 11:11 PM
Porch: Post to beam Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 4 06-03-2007 10:40 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
