You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 08-12-2007, 10:36 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Plumbers & Electricians Should Not Be Allowed Power Tools
The electrician was trying to keep his wires inside the framed wall in this basement so sheetrock could be installed without interference from the wires. This is a non-load bearing (floating) wall beside the basement stairs. He drilled through the top plate of the floating wall and through the bottom flange of the engineered floor joist. That basically killed this joist. Luckily this is a double joist being beside the stair opening but I wrote it up anyway as possibly needing repair (monitor and repair as needed).
It would have been very simple for the electrician to have bored through one more stud and come in behind the stairs and then through the web of the engineered floor joist (as is permitted).
This is only the latest example that I have seen where plumbers and electricians butcher the structure to put their stuff in. I remember a few months ago seeing a TJI completely cut in two where the plumber cut it to install his drainpipe below a huge whirlpool tub. Large load (tub full of water and two overweight Americans) + no floor joist = trouble.
Bruce Breedlove
www.avaloninspection.com
Home inspection
Old 08-13-2007, 08:08 AM
Jimmy Breazeale Jimmy Breazeale is offline
Re: Plumbers & Electricians Should Not Be Allowed Power Tools
As a former sparky, I am ashamed to see that. But I have always contended that it is the plumbers who should have special CE courses in the proper use of power equipment. I definitely see a whole lot more defects caused by the pipe guys than by sparkies. Or maybe, from the point of view of the plumbers, we should just take it all the way back to the architects whose designs cause that joist to be positioned directly under the tub drain?
Old 08-13-2007, 09:12 AM
Thom Walker's Avatar
If there was an architect. Most of the time here, if it's under 5000 square feet an architect was never consulted.
The builder (or his spouse) designs, the Client makes on site changes, the builder says "sure" and the plumbers and electricians are left to figure it out.
There are a couple of new builders here who actually go on site. I have noticed that at their places the work sites are always clean and few of these type framing screwups occur. They hold team meetings with the subs before the project and everybody understands that they will pay to correct a screw up of another guy's completed work.
- Paul Fix
Old 08-13-2007, 09:46 AM
Randy Aldering Randy Aldering is offline
I wish I had pictures handy to share. This one is relatively minor compared to some that I have noted. In one instance, an engineered joist was cut and left hanging, so the plumbing could go in. Brand new house. Builders primary worry was whether or not the cherry stain matched on the flooring and railings on the second floor. Oh boy.
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
Old 08-13-2007, 03:18 PM
Quote:
I agree. I have seen MUCH worse. I just happened to have that one handy when I was on IN and decided to post it.
Bruce Breedlove
  #6 (permalink)
Old 08-13-2007, 05:42 PM
imported_John Smith imported_John Smith is offline
It doesnt look like he damaged the wires!
  #7 (permalink)
Old 09-11-2007, 06:57 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Certainly more is better - right?
Eric Barker
Barrington, IL
  #8 (permalink)
Old 09-11-2007, 08:38 PM
Why use the knockout located 12" away when you can cut out the entire web?
Bruce Breedlove
  #9 (permalink)
Old 09-25-2007, 05:29 AM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
In new construction I blame the framing crews and /or the architects. They know where the tub is going and the architect should spec the floor joist lay-out to accommodate the drain plumbing. If the architect doesn't spec it right then the builder should catch it and fix the problem. Everyone should be thinking through the building process rather than acting like automatons fulfilling pre-programmed tasks. I've done enough of every trade to understand the plumber's frustration when arriving at the site he or she observes no provision was made for waste plumbing. It makes you want to go to the van and get a chainsaw.
That's not quite accurate. The human body is just barely more dense than water. If our lungs are full of air we're slightly less dense. So, the tub weighs approximately the same whether it's filled with water or fat people; you can't fill it with both. ie, fat people displace water and so when they get out there's about a gallon left in tub.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
  #10 (permalink)
Old 09-25-2007, 10:24 AM
Brandon Chew Brandon Chew is offline
Quote:
Not if they are standing up in the tub or a good portion of them are above the water level.
Think inverted iceberg.
Now back to our regularly scheduled program....
  #11 (permalink)
Old 09-25-2007, 11:06 AM
John Arnold John Arnold is online now
Quote:
That killed joist don't need no stinkin' monitoring, it needs replacing! Unless it didn't need to be there in the first place, which seems unlikely.
Home inspection
Similar Threads
Tools for the crawl Vince Santos Tools and Equipment 37 04-19-2008 11:13 AM
A+ for effort, but is it allowed? John Stephenson Building Envelope: Home Inspection and Commercial Inspection 5 08-17-2007 05:03 PM
High Line Power Wires Rick Hurst Electrical Systems: Home Inspection and Commercial Inspection 1 08-13-2007 11:35 AM
Is this allowed? John Stephenson Building Interior: Home Inspection and Commercial Inspection 1 06-06-2007 03:22 PM
No power Vince Santos Electrical Systems: Home Inspection and Commercial Inspection 17 04-17-2007 03:05 PM
vB.Sponsors
Ad Management by RedTyger
