Old 08-14-2007, 07:18 PM
David Edens David Edens is offline
Bowed Bedroom Wall
This is my first post, so bear with me Let me ask if anyone knows the likely cause(s) behind a bowing drywall between a bedroom and hallway. It is bowed in one spot inward toward the bedroom. There shouldn't be any piping in between the walls.
Old 08-14-2007, 08:00 PM
Re: Bowed Bedroom Wall
Welcome to THE inspection board.
Quite possibly it was just poorly framed or had a bowed stud or two.
Old 08-14-2007, 09:15 PM
Tim Bruns's Avatar
Tim Bruns Tim Bruns is offline
If this is a "new wall", studs may have been forced in place after being cut a little to big, then hammered in. Or if this is an old wall "original", I would look for changes in load bearing. This settlement would be a bigger problem worth looking into.
"Learn from the mistakes of others, because you won't have enough time to make them all yourself."
Tim Bruns - Hillside, IL
Old 08-15-2007, 06:09 AM
Scott Patterson's Avatar
Hey David and Welcome!
I would say that it is just poor framing. Most likely a stud or two out of place or they bowed.
Scott Patterson
Old 08-16-2007, 06:23 AM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
Welcome David,
RE: Framing .... Could be a "feature" !!
Had one new home final inspection in Houston (couple of years ago) that the builder told the buyer the bow in the wall was an enhancement. Goes without saying they checked other homes of same floor plan and that wasn't quite the case.
Come to find out plumbing vents in slab or wall framing was not quite where it should have been and they just "curved" the sheetrock around the vent stack. Would have been an easy fix with a 2x6 stud, but that didn't cross their mind.
Got it all fixed, but was a typical "chore" with the new home builder.
Cheers - Nolan E. Kienitz, PMP
Dallas Home Inspector
www.NolansInspections.com
Home inspection
Similar Threads
SIngle wall? Clay E White Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 07-26-2007 06:34 PM
Smoke Detectors on AFCI Bedroom Circuit Nick Ostrowski Electrical Systems: Home Inspection and Commercial Inspection 4 07-19-2007 08:07 PM
Direct Vent Located Below Bedroom Window Bruce Breedlove Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 7 07-16-2007 04:03 PM
Electric water heater in bedroom closet? Trey Humphreys Plumbing System: Home Inspection and Commercial Inspection 0 06-07-2007 01:20 PM
Crack in the wall Mike Huppi Building Interior: Home Inspection and Commercial Inspection 17 04-18-2007 11:44 AM
vB.Sponsors
Ad Management by RedTyger
