Old 10-02-2007, 03:59 PM
Aaron Miller Aaron Miller is offline
Senior Member
Grand Framing Green Tagged
Of course, there's nothing wrong with this picture, right? Grand and the municipal inspector passed it off on my buyer as OK.
Needless to say they are reframing this wall as I write this.
Aaron
Old 10-02-2007, 04:17 PM
Dom D'Agostino Dom D'Agostino is offline
Re: Grand Framing Green Tagged
So did the plumbers bash the studs over to make way for the ice maker rough-in?
Old 10-02-2007, 04:20 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Dom,
Now you know if it was the plumber he would have just CUT IT.
Billy J. Stephens HI Service
Old 10-02-2007, 05:08 PM
Rick Hurst's Avatar
Aaron,
I know of the Grand way all to well. Their craftsmanship is not what it used to be.
Old 10-02-2007, 05:45 PM
Martin lehman's Avatar
Martin lehman Martin lehman is offline
Did they cut the stud or did the hit it with a hammer moving to the right??
It's hard to tell in the photo...good catch.
  #6 (permalink)
Old 10-02-2007, 06:07 PM
Aaron,
What's on the stud by the dryer vent cutout?
  #7 (permalink)
Old 10-02-2007, 08:32 PM
Richard Rushing's Avatar
I can hear it now:
Builder: "But, but... I got a green-tag!"
or
"Yeah, I know... I was going to go ahead and fix that in the morning"
rr
Richard Rushing, HCRI
Duncanville, Tx.
  #8 (permalink)
Old 10-03-2007, 05:14 AM
Senior Member
To All of the Above:
The plumber, it seems (for once), was not the rub here. They purposely framed it around the ice maker hose bib. Not a single peen mark on the studs; no bent nails, nothing. Perfectly toe-nailed 3" off layout. Doesn't matter one whit that this triple stud is supporting a huge laminated beam which supports the edge of the 2nd floor and the roof. Grand, indeed!
Unfortunately for this subdivision super, the majority of these houses are selling to a group of engineers from a country where they really know how to educate their engineers (not all immigration is a bad thing), and they have all hired me. OK, maybe not all, but I have done 10 inspection on the same two streets in the last month and have 7 more scheduled.
Last week, while inspecting another of these, I observed at the house next door a little mini-seminar for the subs being performed by the super covering all of the things found in my reports: roofing, weep holes, . . .a very long list. They will not learn all of these before the building is done, even if they try. But, maybe they'll learn something?
Someone asked what's on the stud next to the dryer vent? Other than the dryer receptacle there's some writing in black paint. Probably stuff painted on the pallet of studs before the band was broken . . . maybe an ode to craftsmanship penned by some out-of-work carpenter supplanted by minimum wage carpinteros (not all immigration is a good thing)?
Aaron
  #9 (permalink)
Old 10-03-2007, 01:46 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
What is Grand? Is that a local builder?
Quote:
The framers framed around the ice maker box? Interesting. I have never seen an ice maker box installed before the framing.
Are you sure that is a load-bearing wall? It looks to me that only the triple stud is load bearing.
Does this triple stud appear on the plans or was it "framer designed"? Which brings up another question:
Is there a footing under this triple stud? If there is no footing I would be concerned about that.
Bruce Breedlove
www.avaloninspection.com
  #10 (permalink)
Old 10-03-2007, 02:47 PM
Senior Member
Bruce:
Maybe where you're from they have the construction documents on site. Not here, unless the house is a true custom home and the builder just forgot to roll them up and put them back into his truck.
As to the wall load, if a beam sits atop a wall, that wall is load-bearing. the fact that it may or not be situated perpendicular to the ciling joists is moot.
Though the icemaker bib obx itself was not there when the walls were framed, the plumbing for it was. . .
Aaron
  #11 (permalink)
Old 10-03-2007, 03:32 PM
Gotcha. I keep forgetting that Texas is the land of slabs where the plumbing is in place before the framers arrive.
Bruce Breedlove
  #12 (permalink)
Old 10-03-2007, 04:01 PM
Senior Member
Bruce:
There is just so much stuff that is done here in a really strange fashion or order that the band width does not exist to list it all . . .
That is why they make Patron SilverŪ . . .
Aaron
  #13 (permalink)
Old 10-03-2007, 04:52 PM
Around here basements are common. The water is typically stubbed up in the mechanical room and from there the supply plumbing is run through the framed walls.
They don't do that in Texas? Do they run all the supply piping in the slab? That just doesn't seem right to me. It seems a lot easier to me to plumb a pipe to a location through framed walls than stubbing it up inside a 3 1/2" wall. (Very easy to end up outside the wall and have to jackhammer out concrete to move the pipe.) Plus the fact that it is a lot easier to repair a leaking supply pipe in a framed wall than one in a slab.
Bruce Breedlove
  #14 (permalink)
Old 10-03-2007, 07:31 PM
Bruce, standard practice is to rough in everything in the slab. It is easy to miss the right spot but there is really no other option. You have to put the drains into slab at the right locations so the supply lines are easy after that. All supply connections are made above the slab and home run style to each fixture location.
As a percentage, we get very few leaks under slabs unless there is unusual movement. Very tough to find and fix if you do get one though.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #15 (permalink)
Old 10-03-2007, 07:45 PM
Quote:
One option is to run the supply piping through the framed walls. But I guess that's not how it's done in Texas. And that's fine with me. I guess it's also good for the concrete repair businesss.
Bruce Breedlove
  #16 (permalink)
Old 10-03-2007, 07:53 PM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
You have to arrive 30 minutes early. They'd "trenched per the foreman" 14' to get to the bathroom supplies and drains.
Then the home owner tried to pawn off a two year old SE letter, to approve the work done that day, to my client.
They found another house.
Residential-Commercial-Construction-EIFS-Infrared Thermography
  #17 (permalink)
Old 10-03-2007, 08:12 PM
They don't do that in Texas? Do they run all the supply piping in the slab? That just doesn't seem right to me. It seems a lot easier to me .
Bruce,
Think about it No Crawl Space no snakes,spiders,Leaking Sewage,Mold ect.
Did a few last week no HVAC,Water Heater,Plumbing,Service Panel, Toilets ect or Crawl Space.
I was almost clean when I got back home
Down Side Lots of Pictures of Broken and missing stuff
Similar Threads
Window Inspections/Grand Junction, CO 81506 Ronald Gould Employment: Home Inspectors & Commercial Inspectors 0 09-13-2007 03:09 PM
Green/Eco Building Joe Nernberg Building Envelope: Home Inspection and Commercial Inspection 8 09-10-2007 09:12 PM
Deck framing wayne soper Exterior Systems: Home Inspection and Commercial Inspection 4 05-02-2007 07:49 AM
Broward Homeowner
