Old 10-03-2007, 03:29 PM
Scott Medlin Scott Medlin is offline
Questionable purlin?
Hello friends,
Any thoughts about the left (notched) end of this purlin and the bracing arrangement? Thanks in advance for your input.
Old 10-03-2007, 03:34 PM
Jerry McCarthy's Avatar
Re: Questionable purlin?
FWIW none.
I like the notched purlin support rather than a nailed cleat.
Shall we assume the ceiling joist are running in the same diection as the rafters, otherwise?
Construction Consultant
Old 10-03-2007, 03:53 PM
Hi Jerry,
Thanks for the feedback. I was not wild about brace on the left and was also concerned about the cut-out in the purlin itself on the left end (not a great picture- tight attic to navigate) this in compromising the purlin stregnth- no? Oh, and yes, the ceiling joists are running in the same direction as the rafters. Thanks again.
Old 10-03-2007, 04:08 PM
Here is a close up of the left end...
Old 10-03-2007, 06:21 PM
That was the last 2x6, the one the screwed up when cutting rafters.
I know it exceeds the notching rules, but at least it is not mid-span.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Home inspection
Similar Threads
Questionable Real Estate Advice Bruce Breedlove General Chit Chat: Home Inspectors & Commercial Inspectors 1 08-20-2007 12:22 PM
Purlin brace Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 1 07-20-2007 12:13 PM
Odd Purlin Brace (?) System Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 3 04-14-2007 06:13 AM
vB.Sponsors
Ad Management by RedTyger
