Old 10-05-2007, 06:33 PM
PETER W BENNETT PETER W BENNETT is offline
Cut Engineered Board
Inspected this 6 year old home with TJI'S. The attached photo shows two 6 inch ducts going through an engineered board, possibly a timberstrand, parallam, microlam which does not rest on the beam below which supports a bearing wall above.
I wrote it up recommending review by qualified contractor and all necessary repairs. The buyer's attorney received a fax by a licensed contractor who stated that there is no problem and not future problems.
What's the purpose of the cut board which is under a bearing wall?
Home inspection
Old 10-05-2007, 07:08 PM
buddy brault buddy brault is offline
Re: Cut Engineered Board
Peter, this is being used as a rim board for lateral support of joist. I would say as long as there isn't a series of penetrations and there is no notches in beam your ok. Truss joist web site is iLevel by Weyerhaeuser - The leading provider of structural framing materials and finishing products for residential and commercial applications. . You may be able to down load some of there installation guidelines.
Home Inspection Protection,LLC
Buddy Brault
Old 10-05-2007, 07:41 PM
Looks like it is going through OSB on a stud wall, I can see the studs behind the OSB in the crack between it and the beam.
From the photo, I don't see anything wrong either - no studs cut, beam not cut, TJI not cut.
Old 10-05-2007, 07:46 PM
Scott Patterson's Avatar
This is a cut TJI!
Scott Patterson
Old 10-06-2007, 06:32 AM
So what's the purpose of the board?
  #6 (permalink)
Old 10-06-2007, 09:35 AM
Peter, I think Buddy had it pegged. It is hard to see the detail of what the boards do in your picture, but it appears the cut board is attached to the end of horizontal floor joists which are resting on the lower beam. The rim joist in this case would simply keep the floor joist from rotating.
Does this fit with what you saw on site? Do you have any more pictures?
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #7 (permalink)
Old 10-08-2007, 05:04 AM
Robert Dalga's Avatar
Robert Dalga Robert Dalga is offline
Peter,
You did your job and wrote it up correctly (if you suspect something is wrong it probably is thus defer to a specialist). It sure looks like a notched (two in fact) beam to me in your photo and if it's carring a load above (which most beams do) then it's probably comprimising the strength of the beam.
RJDalga
Home Analysts, Inc.
Kalamazoo, MI
  #8 (permalink)
Old 10-08-2007, 06:43 AM
I think I answered my original question "what's the purpose of the board?"
The cut board is for support for the edge of subfloor.
The photo "board1" shows the squashblocks and tjis resting on the beam.
The photo "board2" shows the cut board is between the tji and beam.
But here's another issue: does the cut board provide "structural" support for the plywood subfloor?
  #9 (permalink)
Old 10-08-2007, 08:48 AM
Quote:
I doubt it.
You would need "framing", i.e. 2x, for that. Ever try to nail into the side of plywood or OSB? Don't count on it for doing much at all.
  #10 (permalink)
Old 10-08-2007, 09:00 AM
Michael Greenwalt's Avatar
Michael Greenwalt Michael Greenwalt is offline
As I look at the photo's the beam/girder does not appear to be cut, though I may be missing something. I have ran across Weyerhauser beams that have had substantial holes cut in them (usually mechanical contractor work) and I usually contact the engineers. Most times thier regional inspector has already observed the beams and contacted the builder/contractor. Recently I inspected one where the engineers had issued a letter to the contractor stating the beam should be replaced but it was not and the house was sold. After my inspection, and action by the contractor, the engineers developed a steel plate to reinforce the beam and certified it.
I was suprised just how much the engineers would accept with thier manufactured beams; it is much more than what they put in writing on the installation instructions. Bottom line though is to contact the engineers directly or have the clients contact the engineers so that a fix can be made.
If I had two faces, would I be wearing this one?
Abraham Lincoln
Similar Threads
UL To Study Engineered Wood Trusses & Fire Bruce Breedlove Inspection News From Around The Net 4 09-14-2007 02:33 AM
Stuccota Board David Macy Exterior Systems: Home Inspection and Commercial Inspection 2 07-24-2007 08:42 AM
On Board Walter Fish Introductions By New Members 1 07-17-2007 05:06 PM
Nice new board! Joe Griffin General Chit Chat: Home Inspectors & Commercial Inspectors 2 04-13-2007 08:41 AM
Wish list for new board. Tim Moreira H E L P ! 4 04-02-2007 09:24 PM
vB.Sponsors
Ad Management by RedTyger
