10-23-2007, 03:52 PM
Cracks through bricks
10-23-2007, 04:13 PM
Re: Cracks through bricks
Cracked / broken bricks need replacement.
Defective grout needs tuck pointing.
I don't see any weeps in the soldier course.
10-23-2007, 04:52 PM
Originally Posted by Clay White
No other interior (or exterior) evidence of movement.
What would you guys recommend, a SE to determine cause and repairs needed? (1997 home).
Clay,
No.
Billy J. Stephens HI Service
10-23-2007, 05:04 PM
While structural issues can cause damage to the bricks, the brick itself is a siding. No different than vinyl or wood siding.
If there were signs of settlement that could have caused this, a SE should be recommended. Did you know that metal can expand up to 7 times it's original size as it is allowed to rust in an area where the oxidization can not flake off, such as in a metal lintle.
The damaged brick does need repair as it is no longer water tight.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
10-23-2007, 07:19 PM
While the damaged brick does need "replacement", brick is also 'not water tight' to begin with, hence the need for weep holes.
10-23-2007, 10:12 PM
Correct, replacement is needed. Bricks do shed water from their surface. I realize that they will wick water and do hold moisture but they shed the majority of the water. Any compromize to the glazed surface, even minor spalling, is need of replacement in my opinion.
www.irsindy.com
(317) 345-1828
10-24-2007, 03:02 PM
It's not "the bricks", it's "the mortar" between the bricks, through which most of the water/moisture goes.
'The bricks" are somewhat good at shedding water ... sheds it right down to the mortar joints, where the water seeps in.
10-26-2007, 07:46 PM
The amount of moisture brick will absorb when exposed to rain or snow depends on how it was fired. Brick intended for exterior applications will typically be fired longer, thereby increasing the water resistance. In cold climates, improper application of brick [such as an exterior application of brick intended for interior use] can result in serious problems.
However, this particular situation requires dealing with the underlying cause of the failure of the mortar bond and the cracked brick. Cracks at the mortar bond are less serious than cracked brick veneer. The underlying cause of movement must be addressed, in order for the repair to take. Chances are good that the steel lintel was improperly installed.
One option would be to write it as repair needed, and leave it to the builder or contractor to do it right. Unfortunately, that may be very expensive in this particular situation. The positive side is that your client is getting their money's worth from the inspection.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Cracks in flue |
Phillip Stojanik |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
22 |
07-18-2007 05:12 PM |
| Liner cracks question |
Eric Laney |
1 |
07-18-2007 05:07 PM |
| Cracks, cosmetic or structural |
RobertSmith |
Building Interior: Home Inspection and Commercial Inspection |
10 |
07-14-2007 04:17 PM |
| Cracks in garage slab |
dan orourke |
4 |
06-24-2007 01:14 AM |
| wall/floor cracks |
Vince Santos |
Structural Components: Home Inspection and Commercial Inspection |
2 |
05-07-2007 08:43 AM |
