Old 11-16-2007, 03:31 PM
Jon Randolph Jon Randolph is offline
Improper Column
Well......
At least they filled it with concrete.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Old 11-16-2007, 03:47 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Re: Improper Column
I believe that is actually a nail bin or barrell.
Now its a termite monitoring tool.
Old 11-16-2007, 04:58 PM
wayne soper's Avatar
Re: Improper Column
Thats funny, a few years ago I called some of those out among other things for a SE and guess what. They had no problem at all with an old nail barrel filled with concrete. So I had to assume that not all SE's are created equal and made an addendum to my report indicating that I disagreed.
Old 11-20-2007, 04:38 PM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
Re: Improper Column
Would you call it if it was a Sonotube?
Unorthodox doesn't necessarily mean ineffective.
I'd write the non attachment or lack of footer if it doesn't have one, but I can't find fault with using a barrel for a form.
We don't have termites. We have winter instead.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
Old 11-20-2007, 04:52 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Re: Improper Column
Chad?
Billy J. Stephens HI Service
  #6 (permalink)
Old 11-20-2007, 05:05 PM
Re: Improper Column
Chad, what you use for a form is not the question. It's what's under that form as in "footing" that was my concern. A leaning support is suspect in any case.
  #7 (permalink)
Old 11-20-2007, 05:06 PM
Chad Fabry's Avatar
Re: Improper Column
Billy, that's the city.It's south. I'm not kidding; except for tiny little 'hot spots' that are no bigger than a neighborhood there just aren't any termites around.
  #8 (permalink)
Old 11-20-2007, 07:20 PM
Re: Improper Column
Quote:
If it is a cast-in-place piling, it needs no footing under it (but I doubt it is a cast-in-place piling), however, regardless of the form or if it is a piling, it will also be required to have steel in it, and I doubt that does.
  #9 (permalink)
Old 11-21-2007, 04:32 AM
Re: Improper Column
Jerry, do you think they may have left some nails in the barrel instead of rebar? haha. Yes, that is also one of my concerns when i see these. What happens when the termites decide winters over and the barrel splits?
Chad, I've been wrong many times but are there any Termite Companies in your area and if so, do they also go on vacation for the winter because if they do I'm moving to rochester and opening one up. What a great deal.
I'm not far from you and the Termites in my area work year round.
I don't, but they do. Really just interested in why they would not be in your area Chad, Sticking my foot in my mouth is just a habit. Sorry , Wayne
  #10 (permalink)
Old 11-21-2007, 09:03 AM
Jerry McCarthy's Avatar
Re: Improper Column
I'm with Rick on this and can see the day when the first termite scout finds that pier post and yells out; "all aboard!"
Construction Consultant
  #11 (permalink)
Old 11-24-2007, 06:45 AM
Re: Improper Column
Quote:
Actually, they had already found it. The wood on the exterior has had termites, but they did not build tues cross the top to get to the girder above it.
www.irsindy.com
(317) 345-1828
  #12 (permalink)
Old 11-24-2007, 06:55 AM
Re: Improper Column
I thought someone would say: 'There are steel hoops there ... you can see them.'
Home inspection
Similar Threads
Column top plate Jeff Beck Structural Components: Home Inspection and Commercial Inspection 7 02-21-2008 06:37 AM
Weep holes, improper spacing Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 1 10-28-2007 10:04 AM
Improper flahing method? Ron Bishop Roofing System: Home Inspection and Commercial Inspection 5 04-14-2007 11:17 AM
vB.Sponsors
Ad Management by RedTyger
