Old 12-12-2007, 03:31 PM
Ron Bishop Ron Bishop is offline
Lower rear wall out of plumb
This structure had a horizontal crack along the lower wall all the way around. The lower portion of the rear wall was way out of plumb. Crawlspace access was not available. This is a stucco house built in 1959.
Any thoughts?
Ron Bishop
Shasta Lake, Ca.
Old 12-12-2007, 03:40 PM
Rick Hurst's Avatar
Re: Lower rear wall out of plumb
Ron,
Movement from a quake possibly?
Old 12-12-2007, 03:42 PM
that is a good possibility
Ron Bishop
Shasta Lake, Ca.
Old 12-12-2007, 04:00 PM
Rick Hurst's Avatar
Ron,
Looks like your area not only has a history of quakes, but you have volcanic activity too.
Get out of there man.
Global Volcanism Program | Shasta | Monthly Reports
Old 12-12-2007, 07:14 PM
Gunnar Alquist's Avatar
Ron,
I see that a fair amount in areas near me with adobe, clay or expansive soils. Particularly homes built from the late '50s through the late '60s. Around here, the footings are generally not very deep and the foundation can rotate, leaving the horizontal cracks along the top of the stemwall and the stemwall out of plumb. I usually find interior floors that are out of level, doors that don't close properly, cracks in walls and ceilings, etc.
Then again, if you don't have expansive soils in your area, it might be a new volcano like Rick said.
What is the circumference of a moose?
Similar Threads
Acceptable Tolerance of Wall Out of Plumb ? Robert Schenck Building Interior: Home Inspection and Commercial Inspection 8 03-25-2008 01:36 PM
Furnace clearance from rear closet wall Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 01-24-2008 02:42 PM
Greetings from LA (Lower Alabama) Jerome Cartier Introductions By New Members 3 07-20-2007 07:18 PM
Plumb vent near valley dan orourke Roofing System: Home Inspection and Commercial Inspection 5 07-06-2007 01:14 PM
Wall plumb John Stephenson Building Interior: Home Inspection and Commercial Inspection 2 06-03-2007 12:34 PM
vB.Sponsors
Ad Management by RedTyger
