Old 12-21-2007, 02:30 AM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Odd Infill Roof Framing
This is new construction. The infill framing where a gable ties into the main roof was framed with rafters and a ridge board. The framers added numerous 2X4 posts along the rafters down to the roof decking below (above the trusses). The posts were nailed to the rafters (2 nails) and toenailed (2 nails) to the decking. The bottoms of the posts are squared off (not cut to match the slope of the decking).
Apparently this framing was passed by the local building inspector. I don't see the need for the posts. Plus I doubt the underlying trusses were designed for the additional point loads of these posts.
How would you report this?
Bruce Breedlove
www.avaloninspection.com
Old 12-21-2007, 08:33 AM
Aaron Miller Aaron Miller is offline
Senior Member
Re: Odd Infill Roof Framing
Bruce:
Green tagged I assume? How about IRC 301.1 and 801.2?
Aaron
Old 12-21-2007, 12:11 PM
Aaron,
Both those codes pertain to design. I have the following limitation in my report: "· Engineering or architectural services such as calculation of structural capacities, adequacy, or integrity are not part of a home inspection." I'm not concerned about the rafters so much as the trusses below that are being loaded with point loads that I suspect the truss manufacturer did not design for.
Would you recommend the builder provide documentation that the trusses can accomodate the point loads from these posts?
Bruce Breedlove
Old 12-21-2007, 01:11 PM
Senior Member
Bruce:
Certainly.
Aaron
Old 12-21-2007, 01:41 PM
That's exactly what I did.
Bruce Breedlove
  #6 (permalink)
Old 12-21-2007, 06:35 PM
Wonder if the framer knows he left all the 'temporary' bracing up?
Yeah, that a definite 'Have a structural engineer verify ... '
  #7 (permalink)
Old 12-21-2007, 09:35 PM
Quote:
Interesting. I had not thought of that.
Bruce Breedlove
  #8 (permalink)
Old 12-22-2007, 10:52 AM
charles buell charles buell is offline
I have to say that the "forest" of supports whether temporary or intended to be permanent really doesn’t load the area of infill any more than any properly in-filled area. These T or L shaped houses often have one roof laying over the top of the other roof and the lapping area is merely in-filled and the adjacent roof carries the load of the in-filled area. You could argue that the forest of posts helps spread the load but I really don’t see how it creates any structural concern. That said the adjacent roof trusses have to have been designed for the adjacent roof overlay----and you will rarely see any design change in the adjacent roof trusses to compensate for a "typical" overlay
Charles Buell
Last edited by charles buell : 12-22-2007 at 10:54 AM. Reason: put words in quotes wrong
  #9 (permalink)
Old 12-22-2007, 11:47 AM
Quote:
That's it exactly. The underlying trusses will see roughly the same loads as they would without the overlying roof (plus the dead load of that overlying roof structure). BUT, instead of the loads being distributed over the roof surface, these loads have been converted to point loads on the trusses. Trusses typically must be designed for point loads such as this.
That said, I doubt the infill framing will overstress the top chords of the underlying trusses. But that is not a call that I want to make.
Bruce Breedlove
  #10 (permalink)
Old 12-22-2007, 08:33 PM
I have to say that the "forest" of supports ...
I see I'm not the only one who thought of that as a "forest" ...
My thought was 'My gawd, that framer can't see the forest for the trees.'
Home inspection
Similar Threads
Framing strut Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 2 12-15-2007 07:00 PM
House Framing Diagram dan orourke Structural Components: Home Inspection and Commercial Inspection 0 11-16-2007 03:59 PM
Roof Framing Jim McClendon Attic Areas: Home Inspection and Commercial Inspection 8 07-21-2007 03:02 PM
Deck framing wayne soper Exterior Systems: Home Inspection and Commercial Inspection 4 05-02-2007 06:49 AM
Steel framing Phillip Stojanik Structural Components: Home Inspection and Commercial Inspection 6 04-14-2007 01:21 PM
vB.Sponsors
Ad Management by RedTyger
