01-05-2008, 08:34 AM
How would you write this up?
How would your write this up?
01-05-2008, 09:16 AM
Re: How would you write this up?
If I'm seeing this correctly, there's a steel plate bridge the gap between the two vertical pieces. It also looks like this setup has been there for several years. That being the case, I would write that it's an unorthodox installation yet appears to be functioning as intended. If its held up the test of time I don't think I'd make an issue of it.
Eric Barker
Barrington, IL
01-05-2008, 09:38 AM
Yes, if they intended to use random scraps of construction debris as shims for piers, I agree.
01-05-2008, 10:42 AM
Jim
I would describe it as “unique.” However, you gotta know that “unique” can mean a lot of things and in this case it looks like a classic CF. PVC drain line piping improperly supported and if this where in seismic country, well … enough said.
01-06-2008, 06:27 AM
Does that drain line go up in between two sections? And if it does why. I would call it as improper for sure.
But I would write it up as follows. " Welcome to Poland"
01-06-2008, 06:37 AM
And waste a perfectly good opportunity to insult the inhabitants of Arkansas? Geez, Wayne. Polish jokes are so last century.
01-06-2008, 08:11 AM
That does it Wayne. I'm calling my relatives and we're making a trip to Connecticut to set you straight.
01-06-2008, 05:37 PM
Geez John, that was kinda harsh, why does it have to be Arkansas? We just got indoor plumbing & such, we're still trying to figure out just how it works!
01-06-2008, 05:46 PM
I’m Polish
01-07-2008, 07:44 PM
You guys spend so much time trying to be funny  How about a vapor barrier. In door plumbing why here in NM they just chuck it out the door
Bill Brady
American Home Inspections
Las Cruces, New Mexico 88011
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| How would you write this up |
Zibby Swieca |
12 |
12-10-2007 12:25 PM |
| How to write up |
dan orourke |
26 |
11-20-2007 09:44 AM |
| How to write up |
Clay White |
Roofing System: Home Inspection and Commercial Inspection |
15 |
10-25-2007 07:39 PM |
| How to write this up |
Jeff Eastman |
1 |
07-09-2007 10:46 PM |
wayne soper |
5 |
04-05-2007 07:28 PM |
