01-13-2008, 05:39 AM
split beam?
I found this beam with a split in it. It is in one of the 4 attics of this 8600 sq.ft. home that I inspected yesterday. The split runs through the entire beam. I am not sure if I should call it out or not. Any suggestions?
Ron Bishop
Shasta Lake, Ca.
01-13-2008, 05:44 AM
Re: split beam?
Picture?????
01-13-2008, 05:51 AM
Re: split beam?
woops...it's early out here
Ron Bishop
Shasta Lake, Ca.
01-13-2008, 05:53 AM
Re: split beam?
Must be real early. I don't see any beams in these pictures.
01-13-2008, 05:55 AM
Re: split beam?
double oops...maybe I should go back to bed!
Ron Bishop
Shasta Lake, Ca.
01-13-2008, 07:36 AM
Re: split beam?
Ron, when I see splits like these that are fully supported across the length of the beam/joist, I don't call them as long as the split doesn't run to the top or bottom edge of the beam. However, if the split has resulted in some twisting or canting of the beam/joist, then I would.
I wouldn't hurt to just make some mention in your report of the condition you observed and include supporting pics.
01-13-2008, 07:55 AM
Re: split beam?
okay...thank you kindly
Ron Bishop
Shasta Lake, Ca.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Split bus ? |
Rick Cantrell |
2 |
10-20-2007 04:23 PM |
| Beam |
Jeff Eastman |
Attic Areas: Home Inspection and Commercial Inspection |
9 |
06-23-2007 12:25 PM |
| General Electric Split Main Panel |
Joseph P. Hagarty |
1 |
05-23-2007 09:04 PM |
| Temp dif split |
Kevin Fuqua |
15 |
05-06-2007 04:44 PM |
| Split Busbar |
Jim Makara |
1 |
04-23-2007 01:59 PM |
Ad Management by
RedTyger
