LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 04-25-2007, 06:31 PM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is online now
Telescopic Adjustable columns
Ran into an interesting situation. Came across a guy that acts like one of the captains on the Sopranos (the guy with the gray hair on both sides). The whole time he stood by the buyer and me, informing us that some of the things I pointed out were "not a big deal". When two hours were up, he informed us that we needed to go since he had some things he needed to do. I actually squeezed another hour in before it was insisted. They guy didn't scare me but it did make me think, being close to Chicago.
Here is the question.
Telescopic adjustable columns with concrete in them. I know it doesn't meet the diameter of three inches but it is filled with concrete. Should it be called out or not? I think I should report that further evaluation is recommend by a structural engineer. Am I right or does anyone have information saying something different?
I say lets merge all the home inspection organizations into one.
Seepaluce
Old 04-25-2007, 06:56 PM
Michael Thomas's Avatar
Re: Telescopic Adjustable columns
"Many inspectors in the U.S. encounter these telescopic columns in permanent use. This is a defect because no telescopic adjustable column has been evaluated by a U.S. evaluation firm and none of their manufacturers cite an engineering report to prove these columns' ability to carry a specific load..."
Adjustable Steel Columns
Old 04-25-2007, 07:21 PM
Joseph P. Hagarty's Avatar
Joseph P. Hagarty Joseph P. Hagarty is offline
They (Temporary Columns) are improperly installed.
Threaded pin goes towards the floor for one.....
Joseph P. Hagarty
Main Line Inspections, Inc.
http://www.householdinspector.com
Old 04-25-2007, 07:36 PM
Kevin Luce's Avatar
I'll have to look that one up. I thought it doesn't matter where the threaded pin goes as long as you make it so it cannot be moved. Examples would be setting it in concrete, securing it to the support beam, damaging the threads I guess would fall under that thought.
Seepaluce
Old 04-25-2007, 09:03 PM
Quote:
The bar still in place to operate the threaded pin precludes that observation...............
Joseph P. Hagarty
  #6 (permalink)
Old 04-30-2007, 06:40 AM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
The threaded end is installed in concrete so that the load is not supported by the threads.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
  #7 (permalink)
Old 04-30-2007, 07:44 AM
wayne soper's Avatar
I see those all the time but have never seen them filled with concrete. Are they filled after install as a stabilizer? And I always see them with the adjusting bar at the top. I always call them as improper but, Any links to code or websites out there? wayne
  #8 (permalink)
Old 04-30-2007, 07:53 AM
Quote:
Which means, I presume, that the threaded end is recessed down into a concrete footing area on a concrete footing, the adjustments for height made with the treaded screw, then, after final adjustments are made, the recessed down area is filled with concrete?
I would say that it depends on the rating of those screw threads.
I've used 90 ton floor jacks, threaded ones, where each jack, and its threads, are rated to take 90 tons. I believe in a recent thread elsewhere it was guesstimated that a small house might weight 50 to 100 tons, which means one jack, maybe two, to support the entire house (make that three to avoid balancing problems). Of course, I used to use 10 or more of those under one house while doing house leveling on older homes.
To me, the weak link in those threaded adjustable columns would be the columns themselves. If the steel wall is not thick enough, and the column not large enough, a tall column could start to deflect (bend) at its mid-point. A typical compression bow like when one overloads a piece of wood by placing to much weight or load on its top - like a vertical ridge support which is bowed.
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/structural-components-home-inspection-commercial-inspection/706-telescopic-adjustable-columns.html
Posted By For Type Date
I have two questions: 1. what would cause the rust inside a This thread Refback 04-25-2007 11:49 PM
vB.Sponsors
Ad Management by RedTyger
